 Post subject: 5400.6 strange problem, unreadable part of disk
PostPosted: March 16th, 2012, 13:50
hello
we have 5400.6 500GB, NTFS boot sector at 63 is readable.
and then after some sectors, is readable nothing until end of the drive.
what is problem ?
 Post subject: Re: 5400.6 strange problem, unreadable part of disk
PostPosted: March 16th, 2012, 14:10
When you say "until end of the drive" do you mean you can read some more sectors at the very end? Or do you mean after you get the first bad sector, all the remaining sectors are also unreadable? If the latter, perhaps translator issue? What model drive?
PostPosted: March 16th, 2012, 14:34
no, readable is disk only at begining, then it's not readable.
we checked with hex editor. Begining ok, then unreadable without any changes
PostPosted: March 16th, 2012, 16:30
.6 have translator issues. I am not good with seagates , so i have no idea what promts it , however the PC3K has an ability to recalculate and restore the translator. So if u have a PC3K - back up all SA data and use those options to get the data.
PostPosted: March 16th, 2012, 16:51
After backup up SA, "Translator Recovery" is the one you should try.
PostPosted: March 16th, 2012, 16:58
Watch out, if the drive also has other issues this command could make things worse.
Dobre
Murphy was an optimist
PostPosted: March 16th, 2012, 17:19
Sometimes it best to diagnose the failure before running commands that could come back to bite you in the a$$.
PostPosted: March 17th, 2012, 5:11
could you tell me commands for translator regeneration ?
PostPosted: March 17th, 2012, 9:14
I have a lot of these in for translator issues - common on this series I have found. Possibly some degradation in SA area of the disk.
Data Recovery Cape Town
PostPosted: March 17th, 2012, 9:33
Dobre
i second what Dobre is saying, and there are no commercial tools to assist with this issue.
