 Post subject: problem after High low level format
PostPosted: March 16th, 2012, 12:58
i`m Iranian and i can`t speak very well...
i have a sea gate hard disk & i high low level format this...but now on BIOS the device is detect but when i want setup win on this i can`t...
error message:
windows can`t find a hard disk
after high low level format what we do???(for example,create MBR & etc)
please help me...!!! :?: :?: :( :(
 Post subject: Re: problem after High low level format
PostPosted: March 17th, 2012, 9:38
You'll be needing to partition the drive.
S
It's always somethin, and if it ain't somethin, it's somethin else - Cptn. Paul Watson.
PostPosted: March 17th, 2012, 14:53
If I can understand what you are saying is this
You used Seagte Sea Tools to do a what Low level format or a High level format with the tool?
When it was done you put it into your Desktop
Now you want to install Windows on this desktop
but when you do and it comes to the install screen it can not see this HDD on your desktop so the program stops and will not move forward
Is this right?
OK What MB are you using?
What is Your HDD SATA or IDE
Does your mother board support SATA with out a driver?
Reason asking is older mother boards did not and you had to make a diskette to do this one with and when first installing windows hit the F2 to put in this driver and move forward
What is the HDD set as inside the BIOS? If you mother board is way too old and you want to do this one and it is SATA and the Windows does not see it then you need to get a SATA to IDE connector and load windows this way.
Other wise there is something else in this one that you are not saying
Iorana Haraharaini
PostPosted: March 19th, 2012, 5:06
Ann is right.
Most likely your motherboard does not ID the drive because you need to load SATA drivers during XP setup.
This is not a windows support forum, but i will give a quick tip:
Look for setting in your bios about SATA mode. Change from SATA (or AHCI) to IDE (or compatible).
That should do it. But this is not the right way. You must find appropriate drivers for the sata controller your motherboard is using and load them using a floppy at the right time by pressing f6 (if i remember correctly) during setup startup of xp.
PostPosted: March 19th, 2012, 8:34
I'm probably missing something here but where did he mention Win XP?
S
PostPosted: March 19th, 2012, 14:03
error message:
haa haa ,
can you tell me what motherboard make and model you have
PostPosted: March 19th, 2012, 14:26
S
He didn't. He also didn't tell a lot of other details.
I'm guessing.
PostPosted: March 19th, 2012, 15:10
Hehe, northwind, dude..., you guessed! :shock: :D
Haha I guessed 7. :D
S
PostPosted: March 20th, 2012, 5:38
http://aps2.toshiba-tro.de/kb0/TSB85017Z0000R01.htm Or do something like this.
http://support.lenovo.com/en_US/downloa ... D=DS013671 This file is an example for Lenovo (Thinkpad).
Find (CTRL-F) "Installing Windows using native SATA drivers" here for pictures: http://h10025.www1.hp.com/ewfrf/wc/docu ... standalone
If you got Windows installed with IDE (Disabled AHCI):
http://forums.guru3d.com/showthread.php?t=313676
https://www.youtube.com/watch?v=Vdk5-Z_0FqE Easy way for Windows XP with video! If you can view it - you're in Iran. :(
Users browsing this forum: Google [Bot] and 340 guests
