 Post subject: Seagate FreeAgent GoFlex 500Gb Beeps
PostPosted: March 17th, 2012, 6:34
I have a Seagate FreeAgent GoFlex 500Gb Beeps continuously
It does not even gets detected
What could be the cause of that motor spindle or firmware ?
 Post subject: Re: Seagate FreeAgent GoFlex 500Gb Beeps
PostPosted: March 17th, 2012, 9:12
Most likely stiction. Unless it was dropped then MAYBE motor spindle, but i would say 9/10 stiction. Very common. Heads did not park and are stuck to platters.
Requires professional service.
Sometimes if drive isn't getting enough power (USB) you can get some strange symptoms.
Data Recovery Cape Town
PostPosted: March 19th, 2012, 13:46
It dOes Not spin it only beeps
PostPosted: March 19th, 2012, 13:51
Well champ .
In your Case the Head of the hdd is stuck on the platter .you need to give it to a DR professional so that he can open the hdd in a Clean Room and try and recover your data .In india this kind of Dr would Be Rs :18750/- Only
Users browsing this forum: No registered users and 99 guests
