 Post subject: Seagate ST3250820AS: ERR App Code incompatible SFL code
PostPosted: April 1st, 2012, 7:18
The HDD can't be detected by PC BIOS. After checking via COM Port by using TTL converter, I read these messages:
Reset
4096k x 16 DRAM
GALAXY - 1_Disk S-6D 09-22-06_15:48
ERR Read App Code
F>R
Code - A6 Track 1599E.0.238 Sns FFF
F>R1
F>R2
F>R4
F>j
The HDD can't enter others levels (e.g. /1, /2, /3, /T, etc.).
I want to get the data back.
Please help !!!
 Post subject: Re: Seagate ST3250820AS: ERR App Code incompatible SFL code
PostPosted: April 1st, 2012, 9:25
[color=#0000FF]
Reset
4096k x 16 DRAM
ERR Read App Code
The problem didn't show "out of the blue", right ? ;)
24hr wrote:
F>R
F>R1
F>R2
F>R4
F>j
Any other command was INCAUTIOUSLY entered ? ( * cough ! * )
No wonder.
Please help !!!
According to what REALLY happened, you can forget it. Let's hope for the best, but it seems the result of incautious tinkering with commands OR attempt to fiddle with the firmware / electronics.
PostPosted: April 1st, 2012, 9:40
Reset
4096k x 16 DRAM
ERR Read App Code
F>R
F>R1
F>R2
F>R4
F>j
Please help !!!
Well,
Do You Know What These commands Do ? .
PostPosted: April 1st, 2012, 11:39
It is the first time I'm using the COM port to communicate with the HDD. I hope to save my private data at home.
The command R4: to read in the App Code
But it seems not work. The return code A6, refer to the info from the internet, it means "Application Code not Compatible".
I don't know what I can do next then. Help me please. Thanks a lot !!!
PostPosted: April 1st, 2012, 11:46
Vain hope.
The drive has OTHER problems and takes much more than a COM converter and hyperterminal.
Many commands of just 1 letter ( !! ) kill the drive in a flash.
And forget the internet.
PostPosted: April 1st, 2012, 12:19
Or can I buy a HDD PCB to fix the problem?
Thanks a lot !!!
PostPosted: April 1st, 2012, 13:19
No it's not the PCB unless you have already done "something" with it.
PostPosted: April 1st, 2012, 23:46
I think this is not its native pcb .
PostPosted: April 2nd, 2012, 11:42
I ensure that the HDD PCB and the HDD body have not been replaced before.
Dear all, what happened to my HDD indeed? What's lost? or what to be written to it?
Can I step by step to check what tables/parameters are missing?
As long as you tell/teach me/share your experience step by step, I will try via the COM port and see what happened in my HDD. Thanks a lot !!!
PostPosted: April 2nd, 2012, 13:06
I give up...
P.S. there are things money can't buy, for everything else there's MasterCard (TM)....
Users browsing this forum: Google [Bot] and 180 guests
