 Post subject: Seagate 7200.4 S.M.A.R.T. command... Error reading S.M.A.R.T
PostPosted: April 2nd, 2012, 0:10
Hi guys,
I have a Seagate laptop HDD with the following specifications:
Seagate 320Gb 7200.4
I need data
detect: yes
I have tried with dku5:
F3 T>/1
F3 1>N1
F3 T> i4, 1,22
F3 T>
F3 T> m0, 2,2 ,,,,, 22
=> all the command are good , but S.M.A.R.T. command... Error reading S.M.A.R.T!
=> I do not understand why? command is missing? please help me. Maybe on this forum or email : khoiphucdulieu@yahoo.com
I'm very grateful, I was completely deadlocked
VERY HAPPY Email WITH ME: khoiphucdulieu@yahoo.com
 Post subject: Re: Seagate 7200.4 S.M.A.R.T. command... Error reading S.M.A
PostPosted: April 2nd, 2012, 2:51
And you wonder why it doesn't work ?
PostPosted: April 2nd, 2012, 3:25
Thanks blackst,
I want to recovery data in this harddisk
But disk is error: ABRT
PostPosted: April 2nd, 2012, 4:56
Were you AWARE of what the commands you used could do and what was the purpose ?!?
The problem of the drive IS and WAS somewhere else, NOW too many things are screwed and the recovery will likely be more "data reconstruction" assuming you can revert the changes...
Sorry but it takes MUCH MORE than simple terminal. Hope you saved the entire service area and ROM even if it had some errors ( ! ) BEFORE applying commands.
PostPosted: April 2nd, 2012, 23:01
I don't know command clear secondary defect list.
I need some command to fix this error. If you have some, please send it to me.
Thanks & best regards
