 Post subject: Samsung HM641JX
PostPosted: January 10th, 2012, 2:41
Hello all,
A quick one: Samsung HM641JX from a G2, has USB-only PCB. As far as head compatibilty goes I am guessing a HM641JI will work as the only difference I'm seeing is the X has USB PCB whilst the I is SATA.
Thanks.
Data Recovery Cape Town
 Post subject: Re: Samsung HM641JX
PostPosted: January 10th, 2012, 2:49
Nick_CT wrote:
Hello all,
Thanks.
Yep :-)
PostPosted: January 10th, 2012, 2:53
Thanks Sean :)
PostPosted: January 10th, 2012, 22:11
Should be compatible.
PostPosted: April 13th, 2012, 2:05
The drive innards can be physically identical but firmware conflict prevents use of a swapped PCB.
drive 1: HM641JX/VPK rev.A f/w: 2AJ10001--from "S2 Portable 640GB" package (HX-MU064DA/G4 2010.3)
drive 2: HM641JI/M rev.A f/w: 2AJ10003--from an HP laptop, 2010.11 label date
Attempting to recover a partition on drive 1, substituted the Serial ATA PCB taken off drive 2.
result: spins up 3x (w/ chirping), stops, not recognized.
PostPosted: April 13th, 2012, 2:51
Yes, because the ROM info was not transferred.
Users browsing this forum: No registered users and 233 guests
