 Post subject: Samsung HDD sounds ...
PostPosted: April 21st, 2012, 8:49
Hi there,
I've got a problem with a 2.5" Samsung HDD HM321HI for Laptops.
The BIOS couldn't regognize the disk and there is "no operating system found" on the screen.
I connected the disk at a external adapter and heard some strange sounds, for me not a typical headcrash or sth. I heard before.
Here, you can hear what I mean: http://www.vidup.de/v/KXnvB/
Someone have an idea what the problem might be?
thanks
 Post subject: Re: Samsung HDD sounds ...
PostPosted: April 22nd, 2012, 5:18
Yes, could be stiction.
PostPosted: April 22nd, 2012, 6:01
Thank you for your reply. Are there any possibilities for a non professional to fix the problem in DIY ?
My read is no if I see some other cases with stiction?
PostPosted: April 22nd, 2012, 21:32
You are correct NO. Sorry without proper tools this one is hard to do and even at times with proper tools this one is hard to do. Sorry no DIY on this one
Iorana Haraharaini
PostPosted: April 23rd, 2012, 9:21
Ann is right. These drives are f****rs. If you truly care about the data, then you have to send it to a pro.
IF you don't really care about the data, then searching in this forum will lead you to some other "advices" and some "success stories". Strangely enough, these success stories all came up the same time, and then the success ratio dropped rapidly.
Anyways, whatever you choose, good luck.
Users browsing this forum: Google [Bot] and 78 guests
