 Post subject: Seagate goflex 750gb can't work
PostPosted: May 13th, 2012, 12:15
Hi
This is my 1st time.
My seagate goflex 2.5" inch 750gb drop on floor. :(
I tried it to connect to my laptop but light blink blink then off. Can't read.
In device manager, USB cable port said detected and windows unable find it.
Then, I tried it to media player but same problem as above. Can't read.
I want back my files inside ext hdd. :(
How to solve it??
Please help me.
 Post subject: Re: Seagate goflex 750gb can't work
PostPosted: May 13th, 2012, 14:52
How to solve it??
Based on your description of the drive's behaviour, you have likely caused internal mechanical damage. Therefore IMHO you will need to use the services of a suitably experienced DR company, if you want to try to recover the files - so you need to decide how valuable the files are to you. Being realistic, doing mechanical work on 2.5" disks is not DIY :(
Stop powering-on the drive - that might cause further damage, depending on what has actually happened inside the drive.
PostPosted: May 13th, 2012, 15:11
I would add : work on 2,5" 750GB DROPPED HDD.
Users browsing this forum: No registered users and 83 guests
