 Post subject: WD2500JB-00REA0 clicking then powering off
PostPosted: May 23rd, 2012, 16:19
Hello all,
I have a WD2500JB. Symptoms are, it clicks 3 or 4 times then powers off. Comes back on and powers off again. swapped pcb and unit does the same thing, but clicks are slightly different. I had the U12 transferred to the donor board and same thing. Replaced the heads, same thing. So I assumed something went wrong with the head transfer so I swapped them back to the donor drive and it work fine. Am I safe to assume the drive has a damaged SA?
 Post subject: Re: WD2500JB-00REA0 clicking then powering off
PostPosted: May 23rd, 2012, 17:05
Not at all.
These drives are well known for alignment issues.
A straight head replacement virtually NEVER works.
PostPosted: May 23rd, 2012, 18:13
thanks for the input, are the head alignment tools worth it?
PostPosted: May 23rd, 2012, 20:05
Alignment tool are not going to help you in this. The problem is else where. Just to buy tools and not understand the drive and how it works will not align the heads again for you and the tools do not do this one for you either.
Iorana Haraharaini
PostPosted: May 23rd, 2012, 23:07
do you have any suggestions on what else the problem could be?
PostPosted: May 24th, 2012, 3:34
As you are using the "trial and error" method, opened the drive before a thorough diagnose (and from all this I suppose you don't have PROFESSIONAL tools - note the block letters) , at this point everyhting can be. Restart from scratch and make a COMPLETE diagnose.
PostPosted: May 25th, 2012, 10:58
I would suggest that the problem is that you are not willing to seek help when it is clearly necessary :D
Nationwide data recovery services for RAID servers and laptops - http://www.harddriverecovery.org/
Users browsing this forum: Google [Bot] and 80 guests
