 Post subject: NVRAM Required for HDP725025GLA380
PostPosted: November 4th, 2012, 12:15
I need NVRAM for this drive.
HDP725025GLA380
PCB Sticker: 0A29775
BA2996A
Thanks in Advance
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: NVRAM Required for HDP725025GLA380
PostPosted: November 6th, 2012, 4:34
What are you going to do with it? :shock:
PostPosted: November 7th, 2012, 4:20
for fixing NVRAM of the existing drive.
No seek after power on. PCB is fine. NVRAM fixing is required
__________
THANK YOU
SHAHI
PostPosted: November 7th, 2012, 6:09
NVRAM is unique (almost) for each drive ...
PostPosted: November 7th, 2012, 8:20
HMM.
It's possible to fix... with a DONOR...
Do you have the backup pls?
__________
THANK YOU
SHAHI
PostPosted: November 7th, 2012, 16:34
When you say "does not seek" do you mean that the drive spins up ok but you cannot hear the heads come off the ramp?
PostPosted: November 8th, 2012, 7:18
nope. it doesn't spin up, heads dont come up... Status comes to READY in doctor, tested pcb with donor, it's fine. NVRAM fixing is required. do u have donor?
__________
THANK YOU
SHAHI
