 Post subject: WD2500JS-55MHB1 Clunking
PostPosted: May 11th, 2012, 2:33
Hello all,
I have a WD2500JS-55MHB1 drive in for recovery. It is running firmware 10.02E01.
The drive has the click of death when powering up.. I have a few of these in stock, so I thought I'd try a head swap.
Before I continue though, I plugged it into my PC3K to back the firmware/modules/ROM up. The PC3K reports it as a:
WDC-ROM-SN #XYZ-----
WDC-ROM-MODEL-HAWK-----
It also reports an incorrect size. It should be 250GB, however PC3K shows it as 7.46GB.
Has anyone had this problem before, and if so is it fixable? Can anyone provide a backup of the necessary modules for this make/model. I have a fairly large PC3K database and have a WD2500JS-55MHB0 in it, but not this exact model.
Could this also be fixed with a PCB/ROM swap?
Many thanks for any help received,
Mark
 Post subject: Re: WD2500JS-55MHB1 Clunking
PostPosted: May 11th, 2012, 2:39
You have PM
PostPosted: May 11th, 2012, 4:13
These drives have alignment problems.
PostPosted: May 11th, 2012, 5:08
Thanks for the info so far.
I have swapped heads on several newer WD drives without the head-alignment problem. I have 3 spare drives for this faulty one, with the correct DCM numbers (I checked the table on the headstack Q&A on here.)
How do you carry out the head swap and fix the alignment problem. Do I need to sit with a screwdriver and keep adjusting the screw until the drive works, or is there an alternative way?
Many thanks,
PostPosted: May 11th, 2012, 11:19
I would advise you to outsource this drive before new problems occur. Pcimage would be able to help you.
www.datarecoveryne.com
Users browsing this forum: Doomer, unknown and 40 guests
