 Post subject: Momentus 5400.3- ST9160821AS-remain bussy need help!
PostPosted: May 11th, 2012, 4:49
Hello my friends i need help from this hdd
Seagate Momentus 5400.3 ST9160821AS
This hdd remain busy, but I have access with terminal, but hdd id,capacity and firmware version not read
Tried to create loader but i have problems with cert code, probabily are defective
when reading surface 0XF77DD have this error code 0X47 "Missed data sync byte"
I need advice from recovery data.
Thanks in advance !
Terminal log:
Selected family......................... : Momentus (Venus)
Selected model.......................... : ST9160821AS
Model by ID............................. : <HDD ID NOT READ>
Detection of HDD COM port baud rate..... : 9600
Test : Saving LDR from HDD
HDD profile file......... : D:\!Profiles\SeagateBara\Momentus (Venus)\cimpina\Data\LDR\SgLDR.ldr
Will be stored........... : ROM, App, CERT code, CERT tables, Ovl 0, Stuff, DRV cfg
DRV cfg reading...
DRV cfg reading......................... : Ok
STUFF reading...
Detecting Stuff position...
Terminal : detecting SA bounds...
SA bounds identified
Result.................................. : Ok
Stuff cylinder.......................... : 0xF7DD
Vendor Data start....................... : 0x1B
PN...................................... :
STUFF reading........................... : Ok
CERT code reading...
Trying to load CERT
CERT Rev................................ : .00E
CERT code cyl. index.................... : 0x8
CERT code length........................ : 0x1
Block 0, 0xF77D : 0x0 : 0x0 (0x1)
Code - 47 Track FFFFF(0F77D).0.000 Sns 000 Rty 027F.82.80FF Rtf 1800 LBA 00000AC4
Operation "Surface reading (0xF77D : 0x0 : 0x0 (0x1))" completed with error! Error code 0x47Description............................. : Missed data sync byte
CERT code reading....................... : Ok
CERT tables reading...
Detecting CERT tables position...
Detecting CERT tables position.......... : 0xF7D7 : 0x0 : 0x19B (0x16)
CERT tables reading..................... : Ok
Detecting ATA Overlay position...
ATA Overlay (0)......................... : 0xF7D9 : 0x0 : 0x0 (0x98)
ATA Overlay (0) reading...
ATA Overlay (0) reading................. : Ok
App code reading...
Initializing Safe Mode...
Switching HDD power supply OFF
Switching HDD power supply ON
Switching into Safe mode................ : Ok
HDD SpinUp.............................. : Ok
Reading boot SA elements...
Detecting App code parameters...
Detecting App code parameters........... : Ok
App cylinder............................ : 0xF783
App length.............................. : 0x2B8
App buffer.............................. : 0x60
Detection of SA bounds by MUX
App code reading........................ : Ok
ROM: CASPER, S-06
Reading ROM............................. : Ok
7>x
Head 00
Zone 00: 0000A - 019B3 1628 (065C) 778.324
Zone 01: 019B4 - 02B47 1595 (063B) 761.904
Zone 02: 02B48 - 04D07 1540 (0604) 730.158
Zone 03: 04D08 - 06A8F 1485 (05CD) 710.800
Zone 04: 06A90 - 0851A 1430 (0596) 682.839
Zone 05: 0851B - 097E9 1375 (055F) 659.340
Zone 06: 097EA - 0B382 1320 (0528) 628.571
Zone 07: 0B383 - 0CDE0 1265 (04F1) 607.142
Zone 08: 0CDE1 - 0ECFD 1210 (04BA) 576.719
Zone 09: 0ECFE - 10161 1155 (0483) 553.113
Zone 0A: 10162 - 11E35 1100 (044C) 522.750
Zone 0B: 11E36 - 13104 1045 (0415) 502.767
Zone 0C: 13105 - 147DE 990 (03DE) 476.190
Zone 0D: 147DF - 15BBB 935 (03A7) 451.826
Zone 0E: 15BBC - 173D0 880 (0370) 421.428
Zone 0F: 173D1 - 17862 843 (034B) 412.698
Head 01
Zone 00: 0000A - 02AA9 1540 (0604) 729.559
Zone 01: 02AAA - 036DD 1467 (05BB) 716.791
Zone 02: 036DE - 04AA1 1466 (05BA) 700.280
Zone 03: 04AA2 - 066A5 1430 (0596) 682.215
Zone 04: 066A6 - 07E5D 1375 (055F) 658.891
Zone 05: 07E5E - 098D5 1320 (0528) 626.666
Zone 06: 098D6 - 0A509 1276 (04FC) 613.095
Zone 07: 0A50A - 0B799 1246 (04DE) 594.416
Zone 08: 0B79A - 0D109 1210 (04BA) 576.440
Zone 09: 0D10A - 0E7E5 1155 (0483) 552.754
Zone 0A: 0E7E6 - 102E1 1100 (044C) 522.448
Zone 0B: 102E2 - 116D1 1045 (0415) 502.333
Zone 0C: 116D2 - 12FBD 990 (03DE) 476.190
Zone 0D: 12FBE - 144B5 935 (03A7) 451.612
Zone 0E: 144B6 - 15DCD 880 (0370) 421.244
Zone 0F: 15DCE - 17005 806 (0326) 391.534
Reserve: 0F76D - 0F89A 823 (0337) 408.424
Total KBAs = 0E1EF035
T>"
Rbit Hard Firm Soft OTF Raw Rhdr Wbit Whrd Wrty Whdr
Limit 10.2 10.2 9.5 8.0 7.5 5.0 7.4 9.2 9.2 6.5 7.4
Hd 0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
Hd 1 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0
1>y
PhysCyl GrayCyl
1st Sys Cyl 0000F76D 00011015
1st 0 Offset Cyl 0000F777 0001101F
1st App Code Cyl 0000F783 0001102B
2nd App Code Cyl 0000F785 0001102D
2nd 0 Offset Cyl 0000F791 00011039
3rd App Code Cyl 0000F79D 00011045
4th App Code Cyl 0000F79F 00011047
1st Adaptive Cyl 0000F7A1 00011049
1st UsrDfect Cyl 0000F7A3 0001104B
1st Alt Pool Cyl 0000F7AB 00011053
2nd UsrDfect Cyl 0000F7CB 00011073
1st CertCode Cyl 0000F7D3 0001107B
1st IntfCode Cyl 0000F7D9 00011081
1st Intf Sys Cyl 0000F7DD 00011085
1st Cert Log Cyl 0000F807 000110AF
1st File Sys Cyl 0000F867 0001110F
1st Thermal Cyl 0000F87F 00011127
1st Decay Cyl 0000F87F 00011127
1st SPLASH Cyl 0000F899 00011141
Last System Cyl 0000F89A 00011142
Copy PhysCyl StartSec length Name
0000 000F777 0000 0002 BA
0001 000F777 0112 0002 BA
0002 000F777 0224 0002 BA
0003 000F791 0000 0002 BA
0004 000F791 0112 0002 BA
0005 000F791 0224 0002 BA
0000 000F777 0002 0003 RDL
0001 000F777 0114 0003 RDL
0002 000F777 0226 0003 RDL
0003 000F791 0002 0003 RDL
0004 000F791 0114 0003 RDL
0005 000F791 0226 0003 RDL
0000 000F783 0000 02B8 AC
0001 000F785 001E 02B8 AC
0002 000F79D 0000 02B8 AC
0003 000F79F 001E 02B8 AC
0000 000F7A1 0000 0001 ServoAdaps
0001 000F7A5 0112 0001 ServoAdaps
0002 000F7CB 0224 0001 ServoAdaps
0000 000F7A1 0001 0014 DriveAdaps
0001 000F7A5 0113 0014 DriveAdaps
0002 000F7CB 0225 0014 DriveAdaps
0000 000F7A1 0015 0189 UsrSlipDftLst
0001 000F7A5 0127 0189 UsrSlipDftLst
0002 000F7CD 0000 0189 UsrSlipDftLst
0000 000F7A1 019E 0189 UsrSlipKBALst
0001 000F7A7 0000 0189 UsrSlipKBALst
0002 000F7CD 0189 0189 UsrSlipKBALst
0000 000F7A1 0327 000A MediaZonTbl
0001 000F7A7 0189 000A MediaZonTbl
0002 000F7CD 0312 000A MediaZonTbl
0000 000F7A3 0000 000A ACFCTbl
0001 000F7A7 0193 000A ACFCTbl
0002 000F7CD 031C 000A ACFCTbl
0000 000F7A3 000A 000A BackUpACFCTbl
0001 000F7A7 019D 000A BackUpACFCTbl
0002 000F7CD 0326 000A BackUpACFCTbl
0000 000F7A3 0014 0018 AltLst
0001 000F7A7 01A7 0018 AltLst
0002 000F7CF 0000 0018 AltLst
0000 000F7A3 002C 0074 DosTbl
0001 000F7A7 01BF 0074 DosTbl
0002 000F7CF 0018 0074 DosTbl
 Post subject: Re: Momentus 5400.3- ST9160821AS-remain bussy need help!
PostPosted: May 13th, 2012, 1:32
Hi fanys, I saw you very lucky when your HDD can load CERT and App code, at least you can extract data with CHS convert.
* Có ba thứ ngu dốt :
Không hiểu biết những gì mình đáng biết.
Hiểu biết không rành những gì mình biết.
Hiểu biết những gì mình không cần biết.
PostPosted: May 13th, 2012, 3:27
I have a certain feeling about the drive has been BUMPED.
Anyway I would try with a loader and see ... "mutatis mutandis" , if user area is accessible.
(for non-Latin speakers : "mutatis mutandis" = "after changing what had to be changed")
PostPosted: May 13th, 2012, 5:52
Thanks from sugesttions but I need loader Seagate Momentus 5400.3 ST9160821AS-firmware 3.05,
I posted in the forum PC-3000 but no news about loader
Users browsing this forum: Doomer, unknown and 40 guests
