DoctorM wrote:
I have a Hitachi Deskstar HDS722525VLAT80. Several ide pins have broken on it.
I understand that PCB swapping requires NVRam swaping for data recovery, but is it possible to swap the PCB but not any chips if you have no interest in recovering the data?
Also, this drive came in both IDE and SATA styles, is it possible to swap the IDE pcb for an SATA pcb?
And the final question: if chip swapping is necessary, is there anybody that actually offers this service?
You need to transfer the NVRAM, or its contents, whether or not you need the data.
AIUI, you cannot simply swap from PATA to SATA without significant changes to the firmware.
The following PCB supplier includes a free "PCB adaptation service":
http://www.donordrives.com/servicesAlternatively, your local TV/AV repair shop should be able to do the chip swap.
The data had already been transferred off the drive so it could be installed in a different system.
While connecting it in the new system the pins got broken off.
Thanks for the info on DonorDrives.com. Are they considered reliable?
Assuming it's cost efficient versus a new drive, I'll go that way.
