 Post subject: WD2500JD - Unreadable Sectors
PostPosted: May 21st, 2012, 3:49
Hello all,
I'm hoping someone can help me with this problem as it's another one I have never seen before.
I have a WD2500-75HBC0 250GB drive in for recovery. Firmware revision is 08.02D08.
The drive is being detected by Windows, but in drive manager it is showing as uninitialised. When I plug it into the Atola and PC3K, both detect the drive OK, but neither can read the System Area.
I plugged it into the Deepspar to try and image it, however every sector on the drive is showing as unreadable. I did a head map, and tried switching off individual heads (there are 6), and also tried reverse imaging in case the faulty sectors are at the start, but all I get are red sectors on the Deepspar.
I tried reverse imaging one block at a time as well, with the same result.
I've never seen a drive where every sector is unreadable, so I'm assuming this is going to be a head or firmware issue?
Can anyone give me any pointers here?
Many thanks for any help,
Mark
 Post subject: Re: WD2500JD - Unreadable Sectors
PostPosted: May 21st, 2012, 7:43
Sounds like Copy/Paste issue Mark :roll: :roll:
http://groups.google.com/group/datareco ... c99ad41151
S.E.
i guess the problem is else where my dear
PostPosted: May 21st, 2012, 8:00
I always double-post my questions between Scott's group and here.
I have had help in the past from people who are not a member of Scott's group, but on these forums. It's always worth asking as many people as possible.
Cheers,
PostPosted: May 21st, 2012, 8:27
PM Sent... :wink:
Users browsing this forum: Majestic-12 [Bot] and 61 guests
