 Post subject: Seagate loader issue
PostPosted: May 25th, 2012, 15:23
Patient: ST3250310AS FW: 4.ADA / .05Z ver: S-1N
To spare the details, the trouble I am having is that I cannot find ANY of these 4.ADA drives that will start with loader. At first I thought it was a problem with the patient. But now, I have tried 4 GOOD , donor drives, and they all give the same result (see below):
Any thoughts or ideas on this peculiarity of this firmware version would be greatly appreciated. (note: Tried varying baud rates, and nearly all options in utility, only 1 modification, all mods except heads, etc. and have been exhausted to no avail...only thing I've not tried yet is HDD BUSY and INIT options...)
It is puzzling as to why the donor drives which have no issues at all, cannot start with their own loader! :shock:
So far, I have tested on 4 donors, and all give the exact result. Any ideas welcomed and appreciated. Also worth noting is that procedure works perfectly on ALL other firmware versions of this model that I have tested!!!
Test : HDD initialization by utility...
Switch HDD PWR supply.... : No
Terminal Reset........... : No
Terminal work speed...... : 57600
Used LDR................. : C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SeagateBara\Barracuda 7200.10 NHawk Plus\ST3250310AS-4-ADA-6RYCHCFS\Data\LDR\SgLDR.ldr
Loaded from.............. : C:\Program Files\ACE Lab\PC-3000\Bin\NewTask\LDR\SgLDR_Init.ldr
Work with HDD through.... : ATA
App...................... : Loading from LDR
Used modifications....... : Fix 'Pending Bug', Fix 'Pending Bug' (fix 2), Fix 'Not Handled Soft Path' Bug, Fix 'Failed sys sect. write', Alow ATA LBA->PCHS conversion, Block saving Alt-list, Skip Loading Alt-list, Block saving System Sectors, Block saving
Load Ovl 0............... : No
Initializing Safe Mode...
Switching HDD power supply OFF
Switching HDD power supply ON
Loading App Loader...
App patching...
Downloading App code...
App code downloading.................... : Ok
HDD SpinUp.............................. : Ok
Reading boot SA elements...
Reading boot adaptives.................. : Ok
Reading Reserve track defect list....... : Ok
Starting App code...
cmd 2A, params 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
(P)
cmd 58, params 0034 0000 0000 0001 3C96 0001 0000 0000 0003 DA6E 0034
Drive is not ready
Starting App code....................... : Ok
Cannot start App!
Cannot start App!
http://pcrecoveryllc.com
 Post subject: Re: Seagate loader issue
PostPosted: May 25th, 2012, 16:13
When I see you online ?!? :D I maybe have the solution.
PostPosted: May 25th, 2012, 16:25
Thanx! :)
Users browsing this forum: No registered users and 215 guests
