 Post subject: Format for subsequent recovery.
PostPosted: May 29th, 2012, 5:02
I can not unlock the Western Digital my book essential usb 3.0. I do not remember my password. The program WD Smartware stated that if you do not remember your password, you have to do the formatting the hard drive.
what do you think about formatting for subsequent recovery? That after, i can restore files? Or can not be accessed even after formatting the absence of the old encryption key?
 Post subject: Re: Format for subsequent recovery.
PostPosted: May 29th, 2012, 5:32
If you can prove ownership then DR-Kiev, PCimage & Einstein9 on this forum should be able to reset the password at a cost.
If you format it you wont have any chance of recovering your data. Your data is encrypted & if the encryption key is changed or the drive gets zero'd when you format it bye bye data.
It all depends on how much value you put on your data?
The only free way is to lose your data & do the format & move on.
Loki
PostPosted: May 29th, 2012, 6:19
The hard disk is completely serviceable.
Inside of it the key of enciphering lays.
I have new PCBA USB the controller with chip Symwawe.
But it not native PCBA. I have bought its new in shop.
Original PCBA which complete with my hard disk has been lost for ever. And consequently I have bought new PCBA.
But access to a disk is closed. I tried to make initialization, but Windows informs on a mistake, that the disk is protected from record.
I do not know as well as be. Help advice. Thanks.
PostPosted: May 29th, 2012, 6:28
Не понятно, а был ли юзер пароль?
Он появился после смены внешней ЮСБ-симвейв платы?
Вам нужны данные или просто живое устройство?
It is not clear, have you set USER pass or not ?
Or it was appeared when you changed USB symwave PCB ?
Do you need data or just want working USB drive ?
Angel Data Recovery
PostPosted: May 29th, 2012, 6:55
RUS:
Спасибо, что ответили. Я видел здесь похожую тему. Но в ней не нашел ответа.
Подключаю винчестер к PCBA, далее через USB к компьютеру.
Открываю WD Smartware и там написано, что диск заблокирован, пароль пять раз не ввели и предлагает его отформатировать.
Программу Unlock.exe (в которой можно вводить пароль вручную) необходимо, как выяснилось, запустить только с диска, который следует расшифровать. Но я не могу сделать инициализацию в Windows, что бы создать раздел, букву, скинуть туда unlock.exe и запустить. Windows тоже ругается, что диск защищен от записи.
Мне нужны данные конечно. Я для этого и купил новый PCBA. Иначе я бы его давно отформатировал и использовал внутри системного блока по SATA.
Вот.
ENG:
Thank you for responding. I have seen here a similar theme. But it did not find an answer.
I connect to the drive PCBA, then via USB to my computer.
I opened the WD Smartware, and it says that the drive is locked, the password is entered five times and did not offer to format it.
Program Unlock.exe (which you can enter a password manually) is necessary, as it turned out, only to run the disk that you want to decrypt. But I can not do the initialization in Windows, that would create a partition letter, there unlock.exe throw and run. Windows also complains that the disk is write protected.
I need the data of course. I'm for it and bought a new PCBA. Otherwise I would have long been formatted and used inside the system unit for SATA.
That is.
PostPosted: May 29th, 2012, 7:50
У вас на диске должен быть VCD раздел , на котором лежит Смартварь-софт . Если его нет, значит что-то не так.
Юзер пароль у вас действительно был ? Вы его устанавливали?
Плату, которую вы купили возможно с другой варью и от другого по размеру диска.
Можете сказать размер вашего винта и подключить его по САТА? Он работает нормально?
Eng:
Your drive should contains VCD partition , where placed smartware SW. If it disappeared , means something wrong.
Do you realy had set user password ?
PCB , which you have bought , possible has different FW and drive has different size.
Can you tell volume of your hdd and connect it dirrectly to PC via sata. Does it work fine?
Angel Data Recovery
PostPosted: May 29th, 2012, 10:03
Самого диска нет в винде как такового. Если подключить по сата, то диск работает нормально. Но считать файлы невозможно без расшифровки контроллером. Программа R-Studio показывает лишь набор зашифрованных файлов, а через USB Контроллер пишет, что доступ к диску запрещен, так как он защищен от записи. 2.79 размер (3TB).
Пароль я не устанавливал. Когда я только достал его из коробки, то просто просто подключил к компьютеру и начал работу. Все настройки были default.
eng
The disc itself is not in the windsurfing itself. If you connect to sata, the drive is working properly. But the files can not be considered without decoding controller. Program R-Studio shows a set of encrypted files and a USB controller says that disk access is denied because it is write protected. Size of 2.79 (3TB).
I did not set the password. When I got out of the box, then just simply plugged into the computer and started working. All settings were default.
PostPosted: May 29th, 2012, 10:53
У вас юзер-пароля нет (если вы его не ставили). VCD раздел лежит в самом конце . Он не шифрован.
Ключ шифрования лежит тоже в самом конце в определенном секторе.
Прекращайте играться чужой платой , вы, банально, можете регенерировать чужой платой неродной ключ на нужное место. Если данные очень нужны , несите срочно к дата-рековери мастеру (если уже/еще не поздно). Во Владике , я могу вам подсказать одного хорошего специалиста. Если нужны контакты , маякните, я напишу в приват.
Angel Data Recovery
PostPosted: May 29th, 2012, 23:25
вы полагаете, что своими силами я уже не справлюсь?
Как я понимаю, если диск не открывается, значит родной ключ на диске не подходит к этой новой плате. Значит ключ жив.
Как получить доступ к виртуалке на этом разделе.
PostPosted: May 29th, 2012, 23:26
Если спец толковый, зачем в приват. Пусть люди знают к кому обращаться в будущем.
PostPosted: May 30th, 2012, 8:01
http://diskdoctor.ru/
www.datarecoveryne.com
Users browsing this forum: No registered users and 80 guests
