 Post subject: Hitachi PCb
PostPosted: May 29th, 2012, 14:31
i have got APR2009 (customer) with pcb demaged, i can not read nvram.
i found a donor (FEB-2009) but pcb looks different and there is also U7 chip ( that in patient is missing not becouse was removed)
i am not sure it is a compatible pcb..
 Post subject: Re: Hitachi PCb
PostPosted: May 30th, 2012, 2:21
Normally you match the numbers on the sticker of the PCB to get a good match and not the date on the label.
Iorana Haraharaini
PostPosted: May 30th, 2012, 2:28
i matche the model of hdd
PostPosted: May 30th, 2012, 2:30
Did you understand what I wrote. On your PCB is a white label you need to match this label to get a good match for your PCB.
Iorana Haraharaini
PostPosted: May 30th, 2012, 4:53
I agree with Ann. the ones on the pic are not compatible.
PostPosted: May 30th, 2012, 16:35
@ Ann
it's not a matter of understanding that there is a label with a number, it's that some models of pcb even if have different number are perfectly compatible.
@ northwind
thanx anyway.. pcb was faulty becouse spindle motor was blocked,heads were sticking on the platters, probably for a suddenly power off of the external box power supplier.And customer left hdd powered for too much time later on leading the pcb faulty.
PostPosted: May 31st, 2012, 5:03
So stiction + pcb. Careful with these, esp. if the drive has sustained such violent behaviour, heads could be damaged too.
Good luck! ;-)
PostPosted: May 31st, 2012, 9:11
Not that I tried this, but I think most likely the ROM versions will be different between those PCBs.
But you can experiment and see what happens, right?
PostPosted: May 31st, 2012, 10:33
match first 2 lines of the pcb sticker
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: May 31st, 2012, 15:20
Quote for refused at the end from custoner..
@ shahij
thanx for tip
Users browsing this forum: No registered users and 234 guests
