 Post subject: Hitachi IC25N080ATRMR040-0 After NVROM replace - no acces
PostPosted: June 9th, 2012, 16:59
Welcome all.
My old hdd was down day afrer without any reaso. This is a little bit old HDD 4200rmp.
Anyway - found another one on Ebay:
Model - this same
P/N - this same
MLC - this same
Replaced PCB, resoldered NVROM, and dont know what next. HDD is recognize in BIOS, Widows 7 can see this but could'tn do any "properities" and operation.
take look screen from Hard disc manager. When I try to do anything on / with partition, nothing happen.
 Post subject: Re: Hitachi IC25N080ATRMR040-0 After NVROM replace - no acce
PostPosted: June 11th, 2012, 20:02
Was the donor PCB compatible?
PostPosted: June 12th, 2012, 12:03
Use recovery software such as R-Studio if you need files.
If you don't need files, replace drive and move on.
www.datarecoveryne.com
PostPosted: June 12th, 2012, 13:44
Number on PCB sticker was different. Perhaps good idea is replace flash also ? with CPU I might have a little bit problem. I will have look R-studio first.
Users browsing this forum: No registered users and 88 guests
