 Post subject: WD400j lost data. bios sees 4gb, winxp wants to format it
PostPosted: June 15th, 2012, 8:36
my 40gig WD400j drive lost all data. bios sees only 4gb, windowsXP does not see any capacity at all and just wants to format the drive.
tried to plug it into another computer and using different cable. does not work.
tried mhdd .wdctrans command. nothing happened
SMART scan on mhdd gives this result
what to do? im a dummy if its about hardware, and its my dads drive. has some important data on it
 Post subject: Re: WD400j lost data. bios sees 4gb, winxp wants to format i
PostPosted: June 15th, 2012, 11:10
That SMART reading does not seem accurate. Either was not read from the disk at all, which I doubt, or the SMART part of the firmware is corrupt.
What complete MDL drive is that? And does it click at all? Have notice any slower performance/data access issues before failing?
PostPosted: June 15th, 2012, 13:46
before fail nothing was slowing down normal reactions. i did the smart test on 2 mhdds. 1 was a floppy disk, the other one was iso img on cd. both downloaded from the main website.
what does mdl mean?
and what clicks do you mean?
sorry, im not a hardware techie :(
PostPosted: June 15th, 2012, 15:06
MDL= model, located on the label on the drive
Clicks = meaning drive behavior/noise coming out of the drive once powered on.
PostPosted: June 16th, 2012, 11:42
drive magnetic head went to shite. case closed ;/
PostPosted: June 16th, 2012, 12:02
Magnetic heads assembly can be replaced by a professional if data is important.
As long as there is no media damage, there is always a chance.
PostPosted: June 16th, 2012, 12:56
well there is no time for that, thanks anyway
Users browsing this forum: Google [Bot] and 81 guests
