 Post subject: WD5000AZRX 500GB PCB wanted
PostPosted: June 16th, 2012, 8:11
Accidently Ive broken my sata pin (the 7th) on my HDD (WD5000ARZX Cav Grn 500GB). Does anyone have the PCB for it? The drive byitself worked perfectly before without any smart errors.
 Post subject: Re: WD5000AZRX 500GB PCB wanted
PostPosted: June 16th, 2012, 8:15
Fix that SATA pin.
www.datarecoveryne.com
PostPosted: June 16th, 2012, 8:16
harddrivespecialist wrote:
Fix that SATA pin.
That's going to be hard :P I cant solder anyway..
PostPosted: June 16th, 2012, 8:17
You will have to solder new PCB to adapt it to your original drive, plus you will pay good money for PCB.
PostPosted: June 16th, 2012, 8:20
i was waiting for someone here to post such MODEL hehe
this is 771824 pcb right?
i was reading about it, but never had one in hand to get more details
but whatever is the case, you will find real problem finding this pcb since its new
maybe buying new hdd and use the pcb
OR
As mentioned before, FIX IT OR get someone to FIX it for you
good luck
PostPosted: June 16th, 2012, 8:27
OR
good luck
Yep you're right its a 771824 pcb :D But I barely know how to repair a sata pin, cant find any vid on youtube for it..
PostPosted: June 16th, 2012, 8:28
Take it to electronics repair shop...
Users browsing this forum: Google [Bot] and 281 guests
