 Post subject: RES can't be converted
PostPosted: June 19th, 2012, 9:58
I tried to convert this RES from SD to convert, but the CONVERT BUTTION Invisible. Attached one... Anyone was successful to do this one?
The Converter - http://www.salvationdata.com/downloads/ ... -tools.zip
This is Resource file to LOAD FROM FILE for this drive - WD5000AAVS-00ZTB0
RES.rar [11.63 KiB]
Downloaded 281 times
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: RES can't be converted
PostPosted: June 19th, 2012, 11:27
1st. of all, do u know WHY not working?
PostPosted: June 19th, 2012, 13:24
NO
Note: the RES file was collected as donor - seems the RES was taken by old version of WD, that's why it's not compatible with NEW VERSION of WD. That's why need to convert it.
__________
THANK YOU
SHAHI
PostPosted: June 19th, 2012, 14:13
the key is HEX
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: June 19th, 2012, 14:28
shahij wrote:
NO
1st. i agree with the post Hex is the key
2nd. you may also get into it without even converting. figure it out
good luck
Users browsing this forum: No registered users and 168 guests
