 Post subject: Very bad material WD.
PostPosted: June 20th, 2012, 11:21
A customer came to me to retrieve his data from this drive. He said that he just bought it just a week ago and it's now not recognized.
The problem related to a very bad material led to a lot of dust on the heads and the surface.
File comment: Date : 09 May 2012
 Post subject: Re: Very bad material WD.
PostPosted: June 20th, 2012, 11:29
long life china :lol:
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: June 20th, 2012, 13:27
Does the drive work as of now?
PostPosted: June 20th, 2012, 14:55
After replacing 8 heads from donor to patient, it's imaging now. :)
PostPosted: June 20th, 2012, 15:16
Very interesting, thanks for the info :)
I remember many years ago (15 years ago?), some WD drives of that era had a similar problem, with flakes from the black coating material falling onto the platters. :( Therefore this is not a new type of problem for WD...
PostPosted: June 20th, 2012, 15:31
Vulcan wrote:
I remember many years ago (15 years ago?), some WD drives of that era had a similar problem, with flakes from the black coating material falling onto the platters. Therefore this is not a new type of problem for WD...
Totally agree with you sir. But those days WDs are failing quickly than usual.
- Date of manufacture : 09 May 2012 and the drive has used for only ONE week then failed, it's weird. :)
PostPosted: June 20th, 2012, 15:34
Understood and thanks again for the info! :good:
PostPosted: June 20th, 2012, 16:00
Not if it was dropped nicely.
Users browsing this forum: No registered users and 66 guests
