 Post subject: ROM Required plz
PostPosted: July 2nd, 2012, 9:41
Guys,
anyone got this ROM plz
WD20EACS-11BHUB0
ROM version................ : 00250012
thanks in advance
 Post subject: Re: ROM Required plz
PostPosted: July 2nd, 2012, 10:36
Here you go..
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 6
>Cyl Count............................... : 256
>Zone allocation table................... : Ok
>SA SPT.................................. : 1980
>ROM:
>Flash Dir reading....................... : Ok
>Dir info (0B)........................... : 0 (24)
>Extended flash Dir reading.............. : Ok
>Dir info (20B).......................... : 377 653 (24)
>ROM reading............................. : Ok
>ROM Data size........................... : 256 Kb
>ROM version............................. : 25.12E
>ROM generation.......................... : 25.13E
>Link table version...................... : 0B.36.
>Caclulated Version...................... : 00250012
>Heads configuration..................... : by map
>Heads number in use..................... : 6
>Switched off heads...................... : No
>Head map................................ : 0,1,2,5,6,7
>ROM Firmware version.................... : 00250012
>Service area:
>SA dir reading.......................... : Ok
>SA Access............................... : Copy 0,Copy 1
Hope it helps :-)
ROM.rar [225.61 KiB]
Downloaded 291 times
PostPosted: July 2nd, 2012, 11:03
Many thnx my dear........
you are the one :wink: :wink: :wink:
Users browsing this forum: No registered users and 108 guests
