 Post subject: WD10EAVS-00D7B1 Kermit Family module 2E needed for recovery
PostPosted: January 12th, 2013, 3:02
I have WD 1 TB Hdd (WD10EAVS-00D7B1) Kermit Family
need 2E module for data recovery
ROM reading............................. : Ok
ROM Data size........................... : 192 Kb
ROM version............................. : 05.APE
ROM generation.......................... : 05.APE
Link table version...................... : 04.3D.
Consolidated ROM version................ : 000500AP
ROM Modules:
Flash ROM dir reading................... : Ok
Modules directory address............... : FIXED
SA regions address...................... : by default
SA Translator loading................... : Ok
Heads configuration..................... : by map
Heads number............................ : 6
Heads number in use..................... : 6
Switched off heads...................... : No
Heads map............................... : 2,3,4,5,6,7
ROM Firmware version.................... : 000500AP
Reading error
Module 2E............................... : Header error
Any help appreciated.......
 Post subject: Re: WD10EAVS-00D7B1 Kermit Family module 2E needed for recov
PostPosted: January 12th, 2013, 5:44
ROM Modules:
Reading error
Afaik that module is not necessary for a working drive.
What is the actual problem with the drive?
PostPosted: January 12th, 2013, 8:54
Hdd Sector is not reading in Data Extractor....... All sector reading black not green....
PostPosted: January 12th, 2013, 9:26
You have PM
Users browsing this forum: Google [Bot] and 134 guests
