 Post subject: wanted: PCB for Fujitsu MHT2030AT
PostPosted: May 5th, 2009, 4:51
I´m looking for a PCB that matches this HDD.
Please see attached photo of sticker.
Thank you very much.
Ric
 Post subject: Re: wanted: PCB for Fujitsu MHT2030AT
PostPosted: May 5th, 2009, 4:53
Why do you think its the pcb ?
Dobre
Murphy was an optimist
PostPosted: May 5th, 2009, 5:29
because this Fujitsu HDD has been connected to a pc with this adapter for 2.5" to 3.5" HDD:
http://www.cartft.com/catalog/il/441
but in the wrong way (power connection on the wrong side).
After this, the HDD was dead.
It should be enough to replace the PCB, isn´t it?
Thank you for any advice.
Ric
PostPosted: May 5th, 2009, 6:06
you may get away with repairing the pcb... tvs...
Zero Alpha: zeroalpha.com.au
PostPosted: May 5th, 2009, 7:21
Uhm... I think the pcb is beyond repair... :D
PostPosted: May 5th, 2009, 7:26
Mhm, how can I repair it? There is no visible damage.
PostPosted: May 5th, 2009, 7:55
Check the fuse.
If not I can supply you a PCB for this.
PM me if interested.
PostPosted: May 5th, 2009, 17:11
pcimage wrote:
Check the fuse.
how do I check the fuse? Where can I find it?
Thank you,
Ric
PostPosted: May 5th, 2009, 17:27
Post a hi-res of the PCB (component side)
PostPosted: May 6th, 2009, 3:22
Hs,
here´s the pic.
Ric.
PostPosted: May 6th, 2009, 3:34
The fuse is top left, marked with an "N".
Use a multimeter to check continuity, it should be closed.
If it's open, either replace it or bridge it.
If that doesn't work right away, then switch it off quickly, you need a new PCB.
If it does happen to work then copy off your data QUICKLY! This should be considered a temporary fix only, as the drive is no longer protected.
Good luck!
PostPosted: May 11th, 2009, 14:58
He connected the adapter reversed. That means the power was fed to some port bit lines and GND... those lines are dead, and the processor could be also. It is hardly a fuse problem.
PostPosted: July 8th, 2012, 2:29
Good luck!
I just register to say... THANKS!!! I know this thread has long time... but you just safe my life, I made the same mistake, I just bridge the fuse and i´m able to recover my info, thanks a lot... really!!! :D :D :D :D :D :D
Users browsing this forum: Google [Bot] and 218 guests
