 Post subject: Is there a difference between Seagate AS and ASG models?
PostPosted: July 9th, 2012, 10:59
All,
Same question as in the subject line - does anyone know if there is a difference in AS/ASG Seagate drives as far as head compatibility is concerned? Having trouble locating a donor matching the full (*ASG) model, but there is a decent amount of *AS drives that should be good to swap with.
Thanks,
Dizi
 Post subject: Re: Is there a difference between Seagate AS and ASG models?
PostPosted: July 9th, 2012, 11:07
Your best bet is to contact Eric Lee on this forum to see if he has compaitible heads or you can contact donordrives.com. They will also check the headmap on the donor to confirm it matches (assuming you have a PC3000 UDMA, Atola or SD tool to check the patient drives headmap)
Loki
PostPosted: July 9th, 2012, 11:19
ASG has free fall sensor, AS doesn't. Makes no difference for recovery process
PostPosted: July 9th, 2012, 11:21
Thank you Doomer. So would a headswap work across the two, or is the sensor actually built onto the heads assembly (I've never been shown the sensor itself, so I admittedly don't know where it is located).
Dizi
PostPosted: July 9th, 2012, 11:33
Sensor is on PCB. Sensor is not related to heads
Users browsing this forum: No registered users and 408 guests
