What does this stupid HD need?
PCB replacement with chip programming. 0%  0%  [ 0 ]
New Heads. 55%  55%  [ 6 ]
Who knows? ... send it to a pro for a billion dollar bill. 45%  45%  [ 5 ]
Nothing ... you are SOL, buddy. 0%  0%  [ 0 ]
Total votes : 11
 Post subject: WD5000AAKS-00A7B2
PostPosted: July 11th, 2012, 17:53
Subject hard drive quit on me, mid computer use. Upon reboot it was making the attached noise - some sort of soft clicking pattern 6 times, then 2 times .. then repeat. BIOS will not find the drive.
I removed the PCB and saw some oxidation but no obvious signs of anything fried. Used a soft white eraser to buff off oxidation as a Hail Mary - but no luck. :evil:
HD details: MDL: WD500AAKS-00A7B2; NUMBER ON BOARD: 2060-701590-000 REV A; NUMBERS ON WHITE BAR CODE STICKER: 2061-701590-L00 01P, XC 7G04 1P1F L 0003170, 9173
Here is a link to my horrible attempt to capture the sound the thing makes: http://s000.tinyupload.com/?file_id=060 ... 9971635495
So ... should I try the PCB swap (with chip reprogramming) for ~$100 ... or does this sound like a head problem, requiring the full monty?
Thanks in advance for your comments.
 Post subject: Re: WD5000AAKS-00A7B2
PostPosted: July 11th, 2012, 22:53
Listening to sounds aren't the proper method to diagnose a drive like this. It needs to go to a pro. You could always try the PCB + Rom swap, but may loose $100 in the process.
PostPosted: July 11th, 2012, 23:42
Sounds like a head problem (without actually listening to the recording).
http://www.datasaversllc.com
PostPosted: July 12th, 2012, 0:29
After listening to the sound now (it's very difficult to make out exactly what sounds the drive is making), I'd have to agree with Jono-ats, it sounds like a head problem (though could be a "weak" and not "bad" head). :)
But could also be firmware or PCB problem. But it's all speculation without a real diagnosis.
PostPosted: July 12th, 2012, 10:49
heads most likely =( BTW call Jono at data savers. U might be surprised.
Users browsing this forum: Google [Bot] and 217 guests
