 Post subject: lots of bad blocks at end of disk
PostPosted: July 16th, 2012, 3:13
I have a 250gb toshiba laptop drive. I did a scan with MHDD. I got a lot of bad blocks right at the last GB of the disk. over 200+. and tons of blocks that had high read time 500ms+.
For instance, the first 249GB of disk took 1 hour to scan, the last 1GB about 40 minutes or so.
has anyone seen this? and what is the diagnosis? at the moment that space is not allocated on my disk, so I am good to keep using it I hope. has MAC OS on it.
one dumb questions, during the "live" mhdd scan, is it sorting sectors or blocks by read-time on the GUI? the log file for the makelog command seems to return sector-specific data, so I'm confused.
 Post subject: Re: lots of bad blocks at end of disk
PostPosted: July 16th, 2012, 4:24
Seen a lot of times.
Solution : backup and replace as a DEFINITIVE solution is not doable by end user.
PostPosted: July 16th, 2012, 5:59
ok I'll do that. thanks for reply.
Users browsing this forum: No registered users and 242 guests
