 Post subject: Hard disk Samsung HD403LJ Problem
PostPosted: July 7th, 2012, 10:00
Hello, my Samsung HD 403LJ just broke down and I was hoping that I can get some help on this forum.
The drive no longer receives power. I measured the voltage from the SATA power supply connection just before the 2 components circled in red there is power there but after the components there is no power.
Also the ends at the motor when measured show 0.3 volts.
I also measured a working Samsung 320 GB Hard Drive. The voltages at the motor show to be 6 volts.
I need to know what are the components circled in red and if the drive can run without them.
The other two black components circled in red have the following written on them:
The upper one has a revers C and some sort of double ii 814 HE or LE I cannot tell if it is a H or a L due to a small crack on it
The lower one has 818 L E and again the same revers C and ii
Also the PCB is:
BF41-00133A for HD403LJ
Main Chip: 8816725S-TFJ1 YPM14843 0806 B0P TW
 Post subject: Re: Hard disk Samsung HD403LJ Problem
PostPosted: July 7th, 2012, 11:23
Measure the resistance of the 2 bigger components circled in red on the right side. What do they read?
Data Recovery Cape Town
PostPosted: July 7th, 2012, 13:53
the botom one starts from 670 and goes down to 650
the top one is 005 and the multimeter beeps.
I selected the diode measurement on the multimeter.
I think its a zener diode
so perhaps that one is blown ? will the hard drive run if i remove it and just sodder a wire in its place ?
PostPosted: July 7th, 2012, 13:56
Make a search for TVS and you'll get the information needed.
PostPosted: July 7th, 2012, 14:56
on the forum you mean ?
also I forgot to say. I have current on the side with the 125F 16V side, but no current on the side after the 000 component.
Any ideea why is that ?
PostPosted: July 7th, 2012, 15:32
One which beeps is blown TVS (Transient Voltage Supressor). Very similar to Zener diode, but different purpose. Unsolder it, check drive is working. In the long run you need to replace it with similiar type.
PostPosted: July 7th, 2012, 15:34
Also i think that the 000 fuse is blown as well because I dont have any current after it. So do I need to solder a wire in place of the 000 fuse and the diode ?
I tried this once and it did not work. the pc wouldn't power on.
PostPosted: July 7th, 2012, 15:48
Unsolder TVS first. Then check 000 resistor, multimeter should beep.
PostPosted: July 7th, 2012, 15:59
the value of the 000 fuse is 1358 ohmi
also like I said before i have no current after it there should be 5 volts there but there are none.
if i just use a simple wire in its place the pc will not start the PSU wont let it
PostPosted: July 7th, 2012, 16:24
:) This is because you didn't unsolder TVS!
PostPosted: July 11th, 2012, 17:37
Hey darthcornel
After reading your post im replying to say thanks to forum members and to give you a solution.
I had a problem same as you just yesterday, with same HDD model.
I connected the hdd to an outside power source and it smoked from the top TVS.
I checked the components and noticed that : fuse was broken as well as the TVS.
Solution:
TVS circuit must be open!
Fuse circuit must be closed! (soldered a wire down or just using plain solder can solve that)
My HDD is fully working in spite of future problems to come. It will serve now as a backup HDD and not a 100% PC HDD has i read somewhere it can melt or catch fire because of the pieces i removed protect it against overvoltage.
Thanks again
PostPosted: July 13th, 2012, 17:57
More likely electronics will just stop working, as there is no spike protection anymore. Better find TVS replacement. If drive won't fail in the first 2-6 month, you can return it to the normal use.
PostPosted: July 16th, 2012, 17:25
Hey guys,
I am indeed looking forward for my hdd repair. I cant read que components code but found out a high-res image which gives me the codes for the TVS component but im having a hard time finding a seller online.
http://obrazki.elektroda.pl/1430104100_1331063357.jpg
TVS Ref:
QE R734
Can you guys help ?
Thanks in advance
PostPosted: July 18th, 2012, 9:02
The one marked with arrow and similiar size little bit down are TVS's. One for 12V, one for 5V power line. You have to remove faulty TVS before going the next step!
Both TVS's are serial with fuse. The botton one is marked '0'. Checking procedure identical as above. The fuse on the top (green) marked "125F 16V" is resettable fuse - called polyswitch. Check continuity like normal fuse. If 0 Ohm, must take another step and test voltage drop when drive is powered on. It shouldn't be higher than 0.1V.
Users browsing this forum: No registered users and 110 guests
