 Post subject: Seagate ST3250410AS clicks heads
PostPosted: July 19th, 2012, 15:36
Photo:
http://fotki.yandex.ru/users/t9118359605/view/467211/
Drive clicks head,. Bios does not detect it. In the terminal, with each sound head writes "HM".
Photo:
http://fotki.yandex.ru/users/t9118359605/view/467215/
This file is the sound of clicks: https://docs.google.com/open?id=0B3p1hWfi6mIlYkNSYzE0ODRoVWc
After about a minute he turned off.
Me to recover the data. Which in this case, the fault most likely?
 Post subject: Re: Seagate ST3250410AS clicks heads
PostPosted: July 20th, 2012, 3:30
olkon wrote:
Photo:
Photo:
Heads are bad, stop playing with it.
PostPosted: July 20th, 2012, 9:48
Thank you, but there are a couple of questions:
About the head - that's your assumption, or an accurate diagnosis?
A simple replacement of heads helps in such cases?
PostPosted: July 20th, 2012, 10:37
A "accurate" remote diagnosis is impossible remotely :D
A "simple" head exchange might well solve the problem, but there could (probably is) be underlying issues.
PostPosted: July 20th, 2012, 10:42
Read this, but don't play anymore with the drive:
http://www.datarecoverytools.co.uk/2011/01/29/how-to-test-seagate-drives-heads-for-hdd-repair/
As is written, HM means head are damaged.
Good luck.
My firmware database:
PostPosted: July 20th, 2012, 10:48
Heads for sure, maybe platter damage also
PostPosted: July 20th, 2012, 10:54
The main problem would be to replace the heads, I understood correctly?
PostPosted: July 20th, 2012, 11:02
Well not problem, but solution.
Be aware, it is not as easy as it looks if the person performing the work is inexperienced with the technique.
PostPosted: July 20th, 2012, 11:07
Thank you all for your answers.
Users browsing this forum: No registered users and 127 guests
