 Post subject: Need help! WD3200AAJS-07RYA0 ROM
PostPosted: July 23rd, 2012, 4:36
Could anyone hdd guru provide the rom file: WD3200AAJS-07RYA0 ?
 Post subject: Re: Need help! WD3200AAJS-07RYA0 ROM
PostPosted: July 23rd, 2012, 6:42
you will need to specify the ROM version in order to get any help
PostPosted: July 23rd, 2012, 9:33
Maybe he wants to regen the ROM from SA.
Here is one ROM if you want to try it...
>Techno mode key
>Techno mode key......................... : Ok
>ROM:
>Flash Dir reading....................... : Ok
>ROM reading............................. : Ok
>ROM Data size........................... : 192 Kb
>ROM version............................. : 58.3KD
>ROM generation.......................... : 58.3KD
>Link table version...................... : 01.04.
>Heads configuration..................... : by map
>Heads number............................ : 4
>Heads number in use..................... : 4
>Switched off heads...................... : No
>Head map................................ : 0,1,2,3
>Firmware version........................ : 0058003K
ROM.rar [150.94 KiB]
Downloaded 319 times
PostPosted: July 25th, 2012, 4:46
yes !PCB is burn, I want to regenate it !
thanks alot!
Users browsing this forum: No registered users and 371 guests
