 Post subject: Seagate ST3000DM001 3 TB PCB Issue
PostPosted: November 12th, 2014, 5:21
I have a Seagate ST3000DM001 3 TB SATA hard drive (I'll refer to it as Drive A). When I switch on power, PCB (100664987 REV B) gets very hot and drive does not spin. I bought another working hard drive (I'll refer to it as Drive B) with same Model, PN and Firmware. However SN, Date and Site are different from Drive A. I took out Drive B's PCB and fitted in Drive A. But it didn't work. Then, I swapped the 8-pin BIOS chip from Drive A's PCB to Drive B's PCB using heat gun. But, to no avail.
I have noticed that the BIOS chips on both drives are not identical. I was expecting identical chips but the one on Drive A is "cFeon S40-75GIP" whereas Drive B has "Winbond 25040XXXXX 1306". Does that make any difference?
Now I have 2 situations.
1) I have Drive A with Drive B's PCB having Drive A's BIOS chip (cFeon) on it. In this case, there is no sign of life so far.
2) I have Drive B with Drive A's PCB having Drive B's BIOS chip (Winbond) on it. In this case, PCB gets very hot after I power on Drive B.
Definitely, I want to recover data from Drive A. But the newly swapped board won't power up. On the other hand, Drive B has Drive A's PCB but it is at least signalling (by heating up) that there is something in it.
I have also come across many posts on TVS diodes relating to power issues. I can't see anything burnt on both boards. Should I try something like that?
I have highlighted two TVS diodes (In my opinion, please correct me if I am wrong) with red and yellow colors in first image.
Thanks.
 Post subject: Re: Seagate ST3000DM001 3 TB PCB Issue
PostPosted: November 14th, 2014, 4:17
Why is PCB getting to high temperature so quickly? What can be a possible reason?
If I want to check the PSU, can someone point me to right direction?
PostPosted: November 14th, 2014, 10:16
For this statement: "I took out Drive B's PCB and fitted in Drive A. But it didn't work."
Can you elaborate on exact behavior? E.g. no spin, PCB got hot but no spin, etc.
Users browsing this forum: Google [Bot] and 44 guests
