 Post subject: Help - HTS725032A9A364 [ No Data Access ]
PostPosted: July 30th, 2012, 9:12
Guys ,
Got a case from a company that has come to me from other data recovery company .According to the client they could not find the heads for data recovery the top label was removed but glued back .Running the drive i noted It tried to initialise 4 Time Grrr Grr and then comes ready in SD Hitachi tool .I Cannot Iniliatise from HDD hence i have nothing else of the same i select the family as 7250 and i am able to read SA-A and SA-B .There Are Module Curruption In SA-A "Including The Dump " module thats just bad in every hdd .The P list seems to be currupted checksome error .Copying the same from SA-B still has the same modue currupt in sa-a .if i select a working module in sa-a i can change the contents is it still the head issue ?.Attached are the images on the top label , Bottom Side And Screenshot of hitachi tool after reading SA-A .
 Post subject: Re: Help - HTS725032A9A364 [ No Data Access ]
PostPosted: July 30th, 2012, 12:29
What about Factory copy of PSHT?
PostPosted: July 30th, 2012, 13:32
Sean ,
When I Upload The SA-B Copy To SA-A It does Get Copied But The Problem Remains .Like if i check SA-A PSHT After Update Its Still a Checksum Error .for sure This is Currupt But We do not get the checksum error in SA-B .Shall i Get PSHT From SA-C And Overwrite SA-A .I Have Backup already i hate this salvation tool lol
Users browsing this forum: No registered users and 92 guests
