 Post subject: Seagate Barracuda 7200.7
PostPosted: August 5th, 2012, 7:46
I have a seagate barracuda 7200.7 160Gb that has died.
The drive initializes ok and can be seen in the bios and mounted etc. however after a minute or so (it vaires each time) the drive stops responding.
Testing in mhdd shows that the drive goes to busy on and then stay on after a few moments of trying to copy data off the drive using atof.
Does anyone know what could cause this? i know the 7200.11 had a busy on problem but i cant find any reference to the 7200.7 having it and I thought it was on drive power up rather than a few working minutes.
Any advice on whether it is heads or maybe the control board would be helpful.
Thanks!
 Post subject: Re: Seagate Barracuda 7200.7
PostPosted: August 5th, 2012, 8:07
Sounds like bad sectors, or possibly a bad head.
PCB will not make any difference.
Shouldn't be too expensive to recover AT THIS STAGE with the right equipment and knowledge.
If the data is worth anything at all, then suggest you contact member "buster80" who has the equipment and skills for this case and is in Glasgow.
PostPosted: August 6th, 2012, 3:07
+1 for buster80
PostPosted: August 6th, 2012, 5:18
hmm unable to send PM's as have just registered. Would appreciate it if someone could PM him on my behalf and ask him to drop me a message?
Thanks!
PostPosted: August 6th, 2012, 6:23
Thanks!
I have PM'd buster80 for you.
Loki
PostPosted: August 6th, 2012, 6:28
PM'd
thanks guys
andy
Databusters Data Recovery Glasgow
http://www.datarecovery.co.uk/latest-data-recovery-jobs/
Users browsing this forum: nicola and 286 guests
