 Post subject: wd 15eads goes error and busy
PostPosted: August 9th, 2012, 12:10
Hi!
My drive goes "error". Not visible in bios, etc. Looks like Seagate`s CC Error "LED:000000CC"
Victoria in PIO mode shows "ERR". On passport command - BUSY at 1-2minutes, then ERR again.
What can I do to cure my drive?
Please help!
*sorry 4 my english.
 Post subject: Re: wd 15eads goes error and busy
PostPosted: August 9th, 2012, 13:17
Looking for a DIY solution?
PostPosted: August 9th, 2012, 13:51
yes.
i already fix my barracuda drive (CC bug) and i hope to fix this. I was planning to repair disk in Victoria, but disk not accessable. What i can do to get access to the disk? sms like barracuda terminal fix.....? i have COM adapter for terminal access 2 hdd.
PostPosted: August 9th, 2012, 14:53
It's pretty much the end of the road for DYI solutions.
P.S. there might be a small chance that it's the pcb, in which case you can move rom content to a different pcb. But it's not likely the problem. IMOH, other than that, there are no DYI option for this case.
PostPosted: August 9th, 2012, 15:13
+1
These are not easy to recover and recovery procedure is nothing like Seagate. Plus need advanced equipment.
More than anything a good solid diagnostic.
PostPosted: August 10th, 2012, 0:33
Simply every day is not always sunday...
PostPosted: August 10th, 2012, 1:26
wd disk has а terminal? diagnosis stops on err, how to know what kind of error?
drive not emit any suspicious sounds.
PostPosted: August 10th, 2012, 12:15
Can you create a recording of the drive's sounds as it is being powered on?
PostPosted: August 10th, 2012, 14:03
yes. ill try. I need to find a microphone more powerful than in the webcam.
What would you like to hear? the sound of the engine starts? heads "dong-dong"? (= i hear nothing. nothing strange.
__________________________
*you hear retreating footsteps
*sleo gone to look for a good microphone (=
PostPosted: August 10th, 2012, 14:05
Right. I am not sure what your interpretation of strange is. So, I prefer that I hear a recording.
But if it is too much trouble, then no problem.
Not sure what to suggest as I do not understand the behavior clearly. The sounds pattern may clarify some things.
So, it is up to you.
Users browsing this forum: Google [Bot] and 74 guests
