 Post subject: ATA module 0011 in need for WD5000AAKX-001CA0
PostPosted: August 9th, 2012, 14:13
hi,
I need compatible ATA module (0011) for this one WD5000AAKX-001CA0
Rom FW Version: 0003002P
Thanks in advance, fast response required
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: ATA module 0011 in need for WD5000AAKX-001CA0
PostPosted: August 9th, 2012, 17:12
http://files.hddguru.com/download/PC-30 ... 740061.rar
PostPosted: August 9th, 2012, 18:06
Thx for the quick reply Tomset,
do u have full resources in SD format?
__________
THANK YOU
SHAHI
PostPosted: August 9th, 2012, 18:56
Update ---
In this case, when I write it , its successful but after power reset it's lost again.
Then I used LOAD ATA (MANUAL), drive comes to ready, and LOAD FROM HDD Shows everything fine, even under sector view everything shows ok.
after that, I wrote again the ATA MODULE, but still after power reset everything lost.
Thinking for switching for cloning by keeping the power on.
but without the above trics...
Do u think somewhere else need to be fixed to make it working?
__________
THANK YOU
SHAHI
PostPosted: August 9th, 2012, 20:01
Update -
After switching to CLONE by keeping power on... it's very slow...
Did SLOW REPAIR, SMART RESET... nothing worked...
I see I must make it working first (not virtually to RAM)...
Do you have idea what to do next to make it smooth to go on...!
__________
THANK YOU
SHAHI
PostPosted: August 10th, 2012, 5:13
Hello guys,
latest update: after READ/WRITE test....
HEAD 0 and 1 READ ONLY
Any idea about dealing READ ONLY HEAD for WD?
__________
THANK YOU
SHAHI
Users browsing this forum: Google [Bot], mwicwi and 387 guests
