 Post subject: Maxtor STM3160211AS (160Gb SATA) PCB Burn
PostPosted: August 10th, 2012, 9:12
Hi all i have a little problem whit my hdd.
Yesterday i reverse plugged the sata power adaptor and burn one little component on the pcb.
http://kwnetx.net/img/share/PCB-STM3160211AS.jpg
Some one know how i can replace it??
 Post subject: Re: Maxtor STM3160211AS (160Gb SATA) PCB Burn
PostPosted: August 10th, 2012, 11:25
search for TVS and u will have the answer.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: August 10th, 2012, 12:34
it's like zenner diode :D
Ok, i need to make working this disk for max 30 minutes, just the time for transfer my C++ and Java projects.
For you it's a good idea if i bypass it with a wire?
PostPosted: August 10th, 2012, 15:41
Sicuro di aver letto e capito? (per la domanda...)
Are you sure you read and understood? (because of last question...)
PostPosted: August 10th, 2012, 20:35
Ho capito si ma al contrario... Devo rimuoverlo dato che la funzione e di scarico dalla sovratensione, in teoria e in pratica non succede nulla anche se lo faccio andare per un pò senza,,
Se lo bypassavo mi esplodeva in faccia tutta la pcb :D
My english is every new day little worse :)
I understood the opposite... I must remove it because it's function is discharge any overcurrent, in theory and in practice it can work for a while without it.
Users browsing this forum: Google [Bot] and 74 guests
