 Post subject: WD Passport 500GB USB 3.0 Died
PostPosted: August 11th, 2012, 12:20
P\N WDBACY5000ABK-01
i opened the case and on hard drive itself it stated WD5000BMVW-11AMCS2
disk stopped during watching video from it.
if i connect it to usb 3.0 nothing happens
if i connect it to usb 2.0 it seen in device manager - but no drive in "my computer" - and i cannot access any data
http://i.imgur.com/lz0xy.png
any recovery software just stuck if drive connected.
did a research on google, did not found anything usefull
on one forum it was stated that somehow it is possible to connect this drive to sata - is it true? if yes how and will it help me?
can new pcb help in my case?
hope you can help me :)
500 gb of documents\photos and video clips on this hard drive
 Post subject: Re: WD Passport 500GB USB 3.0 Died
PostPosted: August 11th, 2012, 17:11
yes, it's possible to make it converted into SATA, but u require skills to do it properly. otherwise u will mess it up.
Recovery soft get stacked due to errors the drive itself, proper diagnosis will be required why it's happening.
pcb should not be issue in your case as it's detecting, hope it's spinning fine. do u hear any unusual sound?
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: August 16th, 2012, 13:10
no strange sounds...
pleas epay attention that it does not detcted when connected to usb 3.0
so any chance pcb swap woudl work?
PostPosted: August 16th, 2012, 17:35
NO
__________
THANK YOU
SHAHI
Users browsing this forum: No registered users and 186 guests
