 Post subject: Data Recovery Question
PostPosted: August 15th, 2012, 23:58
I have a failed Seagate Barracuda 7200.11 1500 G Bytes. My failed drive diagnosis shows the “read / write heads” stuck to the platters. I have enclosed an image of the hard drive taken in a clean room. My failed drive information:
1. Model Number: ST31500341AS
2. Part Model Number: 9JU138-568
3. Serial Number: 9VS0Q…
4. Firmware: CC3H
5. Site Code: TK
6. Date Code: 09331
I have a Donor Drive I would like to use for the Head Stack Assembly replacement, but have a few questions. I hope some Data Recovery Specialist can help me. The Donor Drive information:
2. Part Model Number: 9JU138-302
3. Serial Number: 9VS21…
4. Firmware: CC1H
5. Site Code: TK
6. Date Code: 09481
According to the Donor Drives Web site, I meet 3 of the 4 criteria.
Hard Drive Match Criteria (for Head Stack Assembly replacement or Platter Swap).
1. Full Model Number
2. Site Code
3. First 3 characters in Serial Number or Full Part Number
4. Firmware
My questions are:
1. Will my donor drive work for the replacement procedure?
2. If not can the Firmware be upgraded to CC3H on my donor drive?
3. Could a PCB swap with matching Firmware work on the donor?
4. Do you know where I could locate an exact match to failed drive?
Any other help would be appreciated.
Thanks,
Bill
 Post subject: Re: Data Recovery Question
PostPosted: August 16th, 2012, 0:08
spindle is probably seized
never seen sticktion on this model
PostPosted: August 16th, 2012, 2:57
+1 and most probably the cause was EXTERNAL
PostPosted: August 16th, 2012, 3:09
From looking at it I would assume seized because 1) it's a 7200.11 and 2) heads are extremely far away from parking area, would most likely be closer to middle or centre if stiction.
Data Recovery Cape Town
PostPosted: August 16th, 2012, 8:07
I've seen the heads seize to the platter because of the drive losing power during operation, but that is pretty rare...and never with the heads that far out. I'd have to agree with the others in that this is mostly likely a seized spindle. I don't think you'll have a problem with your donor drive working if the heads need replaced, but your biggest obstacle is going to be moving the platters...not an easy task even with the right tools and experience.
PostPosted: August 16th, 2012, 8:28
Another +1 for siezed spindle.
If you dont have the hddsurgery tool http://hddsurgery.com/tool/hdds-spindle ... 7200-10-11
then you might want to look at DTI Base Replace http://www.dtidata.com/basereplace.htm
But practice practice practice first
Loki
PostPosted: August 16th, 2012, 8:30
I bought these and they work brilliantly well.
http://www.hddsurgery.com/tools/categories/3
Might be of use?
Kind regards
Logical.
PostPosted: August 16th, 2012, 10:54
From my experience unstuck tools is not the option for these Seagates
And they often bend the spindle shaft too, probably because of heavy packet
PostPosted: August 16th, 2012, 14:51
Actually I have the same model on my shop. It was on a external enclosure. Sounds stuck. Let's see if it's heads or spindle.
ACELab partner
PostPosted: August 16th, 2012, 16:15
Agree, NEVER seen stiction on this model.
Very occasionally on 500gb, but 1-2% at most,
PostPosted: August 18th, 2012, 2:58
i've seen a couple 1tb's with stiction, never a 1,5tb. Anyway it is very easy to find out if it stiction or seized.
PostPosted: August 18th, 2012, 3:00
regarding OP's original question, the donor you're having is compatible for head swap, but as explained by others previously, there are other obstacles.
PostPosted: August 18th, 2012, 13:02
My case had one broken head stuck to the platter.
I don't think the client will accept the budget :cry: :cry:
ACELab partner
PostPosted: August 18th, 2012, 13:20
Oh, and by the way, two 7200.11 500GB with stiction solved today... :mrgreen: :mrgreen:
Already imaging.
ACELab partner
PostPosted: August 22nd, 2012, 0:28
Hi everyone and Thanks for all of your input. I was waiting for a reply from my diagnostic technician before I replied back. According to him the drive platters spin, so that should remove a seized spindle from the problems. Next I'm told that the Read / Write Heads need the same firmware as the original drive. That where my problems is. I do not know if the different firmware will make a difference.
Thanks,
Bill
PostPosted: August 22nd, 2012, 3:33
If it is seized spindle or only stiction, heads might have survived in both cases.
PostPosted: August 22nd, 2012, 5:57
Thanks,
Bill
Your tech guy should now that...
Or maybe not so tech...
ACELab partner
PostPosted: August 22nd, 2012, 12:11
Thanks,
Bill
You have a technician working for you, you have clean room facilities and a HDD workbench, I am assuming this is a clients HDD, yet you cannot tell the difference between stiction and siezed spindle. Also, you ask if PCB swap and upgrade of FW will help, and am prepared to change the heads despite the problem potentially being in the spindle?
Are you even qualified to work on this, and does your client know of your limitations??
Users browsing this forum: No registered users and 138 guests
