 Post subject: Is There any Good Application Which Recover Hard Disk Data?
PostPosted: August 21st, 2012, 7:00
Hi All,
I have a problem with my Hard Disk few days ago i am going to help my friend actually his PC Hard Disk suddenly stop to supporting and when he open his PC a blue screen shows so we decide to check other hard Disk on this system for this I used my Hard Disk in his PC everything is ok it's support after installing new OS but when again I am going to used my Hard Disk in My PC My All Data is not available here and i lost my all data from all Drive first thing i want to know what happen with Hard Disk and how can i recover my all data now.Is there any good application which help me to recover my data back .
thanks
 Post subject: Re: Is There any Good Application Which Recover Hard Disk Da
PostPosted: August 21st, 2012, 9:28
Unfortunately I didn't understand enough of the description, for it to be sensible trying to guess what meaning is intended. :( FYI, I'm fairly sure you don't mean "supporting" or "support", where you have said that. I don't know what you actually mean, but it is probably being mis-translated.
To prevent these language / translation problems, perhaps it would be easier for you to contact a local company in your country. Or perhaps you will be lucky and another member will understand your description... Good luck!
PostPosted: August 22nd, 2012, 4:50
jetchan wrote:
Hi All,
These sort of stories never end well. Why would you offer to help your friend recover his data when in fact you do not have any idea about it?
I assume you have overwritten your data. In this case you should make a complete clone of the media, then run an intensive surface scan against the clone to try and identify data belonging to previous file system, not current one.
At this stage it is a fairly straightforward logical problem, if you are not confident in the recovery yourself it can be resolved quickly and inexpensively if you consult a professional.
PostPosted: August 23rd, 2012, 6:04
hddguy wrote:
jetchan wrote:
Hi All,
Hi Hddguy,
Thank you very much providing me solution my hard disk is checked my by a professional person who told my that you hard disk is corrupted and may be recover but they asked for very large amount so i am searching a solution which is done by myself .Is it possible and thing more data is not overwritten as the professional guys told me now if you have any solution please provide me.
PostPosted: August 23rd, 2012, 8:01
this is such a generic term it could relate to absolutely anything. Did this professional give you any kind of report? Is this professional part of a professional DR company? Is the corruption logical like with partition structures, or related to service area? Or could be data is damaged like was overwritten?
In order for anyone to help you, it is important that we have as much information as possible.
PostPosted: August 24th, 2012, 6:53
Hi Hddguy,
Actually i have not got any report from professional and he is the part of Data Recovery Company he told me only verbally that there are a problem in your hard disk related to corruption and he is talking about partition structure too.
Users browsing this forum: Bing [Bot], Google [Bot], napalm_atx and 71 guests
