 Post subject: Exactly half a disc
PostPosted: August 30th, 2012, 18:01
G'day
I have used ddrescue to read a failed seagate 1T hard drive. DDrescue reported 2 errors and was able to read exactly 500G. I am trying to figure out what sort of failure would result in the second half of the disc to disappear. I have been unable to determine how the sectors have been mapped to the the platters so I though you guys would have a better understanding than I. If anyone could help it would be greatly appreciated.
PS Most of my files have been recovered it was just the most recent that are full of zeros.
Michael
 Post subject: Re: Exactly half a disc
PostPosted: August 30th, 2012, 18:06
Confident to say that it is likely a firmware issue. It is a specific type of firmware issue. Do not think that firmware flashing/upgrading can help.
I do not know of any ordinary tools that could be used to address this issue.
A professional with the proper tools can resolve easily and fairly cheaply.
PostPosted: September 1st, 2012, 12:20
Agreed it does sound like a firmware issue.
ie a corrupt translator would read sectors ok up to the point of corruption & then fail to read / access the sectors onwards (just like in your dd image where you then get data up to a certain point & then zeros) from that point onwards there is no data in your image so the fault on the drive would first need to be fixed ie in my example a translator regeneration with P-list.
As labtech has said it should be fairly cheap to fix for a pro.
Loki
PostPosted: September 1st, 2012, 20:42
Someone has performed an "internet fix" on it?
PostPosted: September 3rd, 2012, 4:27
Seems to me also like a broken translator problem. Search a DR pro in your place. As loki said, it shouldn't be so expensive to fix. Except if the problem lies somewhere else.
Data Recovery in Greece for 250euro + parts.
PostPosted: September 3rd, 2012, 8:21
It looks like it needs "Internet" fix.
What is a boot message from diagnostic terminal? Read carefully what loki said.
PostPosted: September 3rd, 2012, 12:49
Are you hinting at the internet fix for 0lba & bsy bug thats plastered all over the net?
Or they could try regenerating the translator using a terminal cable & the m0,6,3,,,,,22 command? Of cause if they accept the Risks of DIY?
Loki
Users browsing this forum: Google [Bot] and 270 guests
