 Post subject: PCB Match for Maxtor D740X-6L
PostPosted: September 5th, 2012, 9:37
Can someone confirm if a PCB with the same controller chip number and motor combo chip number will work with my faulty drive or do I need to look for other criteria? I have sourced one but it is a different capacity to my drive and I am unsure if that makes a difference with these old drives.
The PCB has blown on the one I have when the client decided to use the wrong power supply with it. Fingers crossed the pre-amp chip hasn't gone as well :-/
 Post subject: Re: PCB Match for Maxtor D740X-6L
PostPosted: September 5th, 2012, 9:43
Donor Drives guide says
Maxtor
Maxtor in 2006 has been acquired by Seagate. For modern models - see Seagate..
PCB Match Criteria (for logic board replacement). No chip transfer / swap or similar adoptation services required
1. Full Model Number. Example: 6H500F0, 4R160L00420P1, 2F040L0
2. Code. Example: RAMB1TU0, VAM51JJ0
3. Controller version. Example: 040108000, 040116500
http://www.donordrives.com/hard-drive-p ... swap-match
Loki
PostPosted: September 5th, 2012, 9:47
For this model just match the 6 digit code at the rear of the HDD, should look something like AVQ1 0520
This should be ok
PostPosted: September 5th, 2012, 9:49
Cheers Loki, I saw that but the only thing that threw me was the code, this one doesn't have a code, everything else is relevant though.
PostPosted: September 5th, 2012, 10:02
This should be ok
Thanks I will look for that also
PostPosted: September 5th, 2012, 11:31
This should be ok
hddguy - that is the exact code I have on the bottom of the drive :) , do you possibly have a donor I could use?
PostPosted: September 5th, 2012, 12:13
D740X-6L were old QUANTUM technology.
As long as they are same series AND there is no "variants" there should be no problem. Really bad news would be if data is still un-accessible or when you power it up and hear "CLUNK-K-K-k-k !" :mrgreen:
Users browsing this forum: Majestic-12 [Bot], MindMergepk and 63 guests
