 Post subject: Very dead HD103SJ
PostPosted: September 4th, 2012, 12:31
Hi there,
I have a Samsung HD103SJ here that spits out the following (at 57600bps):
*PA VID=0000 PN=0004 Rev=0002- 785x Found
ChipRev = 63B0
U
S_0
[DEBUG HALT @MDL_RSRC_BufferAlloc():10034A95 L0 1003A451]
RV En Sensor Circuit
En Shock Sensor Circuit
No spinning, the switching regulator supplying the head amp (+5v - P-ch mosfet - 1.2uH choke) is not working.
I'd assume it's stuck in a very early stage of bootstrapping so it may be normal that the regulator does not get drive.
How adaptive are the ROM contents? I can surely do a PCB swap, but the problem may well be in the flash ROM data...
 Post subject: Re: Very dead HD103SJ
PostPosted: September 4th, 2012, 13:24
Should not be a problem....but can be.
Anyhow if you have an working pcb from the same drivefamily you can make a swap see if it spins up as it should.
http://www.rescue-it.se
PostPosted: September 4th, 2012, 13:28
I'll give it a try. It's probably not worth to invest more work
PostPosted: October 10th, 2012, 12:35
It does not spin up - the fault is very likely to be in the flash eeprom contents. I've cross swapped the boards, the disk having the original eeprom won't start and shows the
ChipRev = 63B0
U
S_0
on the terminal
Users browsing this forum: No registered users and 92 guests
