 Post subject: Western Digital 1TB Caviar PCB board burnout
PostPosted: September 6th, 2012, 17:13
My Western Digital 1TB Caviar PCB board has burned out. I've done a little reading about TVS diodes, but I'm not convinced that's the issue. Can anyone help diagnose the issue and let me know if it is fixable? I just want to run the drive long enough to get data off but it won't power up
http://imgur.com/a/j2yWv
That chip at the back (sorry my camera is not very good) looks to be the part burnt, appears to be U1 on the board
 Post subject: Re: Western Digital 1TB Caviar PCB board burnout
PostPosted: September 7th, 2012, 1:15
Are you good with soldering chips?
PostPosted: September 7th, 2012, 3:16
Nothing to do with TVS, the motor chip is badly burnt.
The chip at U12 is the ROM.
You need to move this chip to a new PCB with the same P/N
Having said that, the burn seems very bad and preamp damage is likely :-(
PostPosted: September 7th, 2012, 4:25
Have 0 experience soldering chips - or fixing hard drives for that matter! Thanks for the help.
Where can I find the P/N on the board? There is 01NF stamped on the bottom of the power/SATA connectors, does that sound right?
Is this possible for me to fix? or is any data recovery possible, or is to likely to be prohibitively expensive/impossible?
PostPosted: September 7th, 2012, 5:08
The number is on the other side of the PCB. Will be something like 2060-xxx etc
Data Recovery Cape Town
PostPosted: September 7th, 2012, 5:18
Edited:
Nick_CT you beat me to it :)
Dam I need to type & post faster :lol:
The PCB imprinted number on the none component side starts with 2060-
But as pcimage has said you would need to desolder & swap the U12 (8 pin chip) over from the damaged pcb to the donor pcb. This chip holds unique adaptive information for your drive.
Also due to the burnt / damaged Smooth chip there is possible damage to the internal component called the preamp.
If you replace the pcb & swap the U12 chip over then fit this to the hard drive & power it up & the preamp is damaged it could damage your donor pcb.
If your accepting the risks of DIY then a pcb swap & U12 swap is all you can do. If this works then great if not the a dr pro is required.
Loki
PostPosted: September 7th, 2012, 5:57
What kind of price range am I looking at for data recovery in London, UK?
PostPosted: September 7th, 2012, 9:38
www.pcimage.co.uk
Users browsing this forum: No registered users and 58 guests
