 Post subject: WD fried board and which is a ROM chip
PostPosted: September 25th, 2012, 6:59
I fried my two WD 1T HDD PCBs. Unfortunately living in a location where there is no data recovery service, so after reading mr google, I found out that I need replacement PCBs but that I will also need to change over a ROM chip from burnt out PCB to the new one.
I found two exactly same PCBs online, I received them, but there is no way I can find out which is exactly a chip that I need to replace.
If someone can please help and identify what exactly needs to be moved over from old PCB to new one.
Disk1
2060-701590-000 REV A
Disk 2
2060-701537-004 REV A
Thanks for your assistance.
 Post subject: Re: WD fried board and which is a ROM chip
PostPosted: September 25th, 2012, 10:47
As you can see by the pictures, the PCB's are not equal, CPU is different and none of them has external ROM, so you cannot swap it.
PostPosted: September 25th, 2012, 10:52
Unfortunately you can't do this on your own.
These boards have no external ROM (U12 is vacant), therefore you will need a pro to do this for you. There is no way you can do this on your own. Sorry.
Judging by the damage on your second pic, I think a damage in preamp is also very likely :(
Bad news.
PostPosted: September 25th, 2012, 10:53
He fried two different drives, as I understand it.
PostPosted: September 26th, 2012, 2:42
Agree, neither of these boards have a rom chip at U12, so DIY is not an option.
Users browsing this forum: Google [Bot] and 72 guests
