 Post subject: Hitachi HTS543216LA Password issue
PostPosted: September 9th, 2012, 6:39
Dear Experts
i was wondering about something related to hitachi Passwords
the issue is not removing it, it is KNOWING IT...
Any Secret way how to know it Manually or by any other method??
Thank you :wink:
 Post subject: Re: Hitachi HTS543216LA Password issue
PostPosted: September 9th, 2012, 16:42
And I am 100% sure this subject is closed and stored within a black box
PostPosted: September 10th, 2012, 4:19
Guru, why is that?
in fact i cannot see any reason for that..
WD can be
SG also can be
i got this idea/question few days back and was wondering why not Hitachi?
if someone KNOWS HOW? just say it is POSSIBLE, the rest is my homework
but if said: NO WAY i will consider it as a challenge and give it priority more to go through it
and thnx for the BlackBOX issue hehe :wink:
PostPosted: September 10th, 2012, 4:26
BlackBOX is a trademark of BlackST :mrgreen:
PostPosted: September 10th, 2012, 4:48
hehehe, to be honest, i knew the BlackHAT (attended there some time ago)
but just knew now the BlackBOX hehehehe
if its possible then i think i should try harder n more
Many thnx
:roll: :roll:
PostPosted: September 10th, 2012, 4:52
ok, so it's within "Schrödinger's Box" :lol:
PostPosted: September 10th, 2012, 8:10
I would assume if this was possible then Acelabs would have already implemented it in their PC3000 UDMA like with Seagate & WD drives. I'm also assuming your looking in to this on the off chance a user uses the same password for multiple things ie documents/websites, logins or maybe forensics?
Loki
PostPosted: September 11th, 2012, 15:02
Loki, some how YES you are right, thats why i needed to know it
Now, BlackST heheheh i can tell u something here about it since you are the BlackBOX here
i managed to open the blackbox and was able to bypass locked hdd`s and managed to read all modules from it
i was testing on one of my drives here, i had a Mod. copies before/after the password set.
I compare both looking into the security Mod. but seems only 2 changed inside which i doubt the pass is there,
since the pass i set is 7 digits (same char.)
I tried also look inside those Mod. (all of them) looking for CLEAR TXT of my Pass. ( not there)
which leads to only 1 (i think) it is not CLEAR TXT AS IN WD
am i doing good so far? heheh
i hate sleeping @ night with something cooking in my mind with NO ANSWER.
thnx
PostPosted: September 11th, 2012, 15:42
You HAVE PM.... :)
PostPosted: September 11th, 2012, 16:48
quote "I would assume if this was possible then Acelabs would have already implemented it in their PC3000 UDMA like with Seagate & WD drives." Oh dear.............. :lol: You think Ace knows everything? Wish there was a face palm Smilie :shock:
Native HGST password is not plain text. And hasn't been for some time..............
PostPosted: September 11th, 2012, 17:46
Nobody knows everything :wink:
I picked Acelabs as an example as they are one of the market leaders in dr equipment & I would assume that they have researched this already.
As far as Im aware the Shinobi can do brute force & dictionary attacks to crack the password?
Loki
PostPosted: September 12th, 2012, 4:25
Thnx guys, am still working on it, seems interesting really
in fact never thought about it till i got this Forensic case here
and Docs pass is never been a big deal really i was thinking about other stuff which the pass might help on and saves my time.
i suggest you try it in your side, and see how you will get through it... really good stuff to know (sometimes)
and btw, i asked Ace TS, one of them told me something (which doesn`t make any sense really, but have to consider it) which means maybe he don`t know, or like some of the Questions that i asked them some time ago and said: ACE Developers SECRETS...
seems not only BlackST has a BlackBOX they do also heheh
:wink:
PostPosted: September 12th, 2012, 6:03
Secret=they don't know
PostPosted: September 12th, 2012, 6:31
not always btw
i remember i asked them once about DragonFly4 (for example) |SelfTest Scripts (on older ver. util)
one Smart Q really, and TS said: cannot tell the answer since its one of their Tool Secrets
which developers made it on a such Enc. way
so that other competitors cannot use those Info. (i mean real R & D work) in their cheap Tools which you see now on the market
heheeh
they are right on this point btw and i Agree with them.
FYI, scripts on older ver. were 4 on new update was i think 7 (added 3 more) if am not missing something
:roll:
PostPosted: September 12th, 2012, 14:32
Hint
In SECI Module stored SHA-2 Hashes of passwords(User&Master)+random salt.
So it's possible( brutforce),but not easily(
PostPosted: September 13th, 2012, 10:27
This subject is REALLY NOT AS EASY AS IT LOOKS....
:wink:
