 Post subject: Asus UX32VD ate my new SSD - HDD Password assignment failed
PostPosted: September 22nd, 2012, 18:50
Nice new UX32VD.....bricked.
I had upgraded it to a Samsung 830 series 256GB drive, and that was working great - the problem came when I attempted to assign a HDD Password from within the BIOS. First I set up a BIOS password. This was successful. Then, I set up a master and user password in the HDD Password part of the BIOS, both times entering my 21 character password twice to be sure it was correct. I got no errors at all during this process, and everything seemed to be working fine.
Then I saved my settings, shut off the power, and rebooted. I was prompted for the BIOS boot password - no problem, I entered it and it let me in. Next came the HDD Password prompt, and that's where everything went pear-shaped. I entered the password that I had so carefully typed previously, and the prompt insisted that it was wrong. It said to press ESC to try the master password, and so I did -- and that one failed as well. :cry:
The worst part about it is that it must have assigned the password to both my new Samsung drive, and to the internal iSSD that is soldered to the motherboard. I pulled the Samsung out and still get prompted for the password, which doesn't work no matter how many times I re-try entering it. I even opened it up and removed the CMOS battery to no avail.
Can anyone assist? I have MHDD on another machine looking at the Samsung SSD, but even with that I still cannot seem to get the password to be correct. As far as I can tell, the UX32VD BIOS munched the password into unreadable garbage, but I have no way of verifying that other than the fact that I can't log in. The worst part is that the machine will have to be returned for service because I can't remove the iSSD for diagnostics.
Any help? :(
 Post subject: Re: Asus UX32VD ate my new SSD - HDD Password assignment fai
PostPosted: September 22nd, 2012, 20:19
UPDATE:
After replacing the original HDD in preparation for returning the computer to the service center for repair, I was actually able to get into the BIOS and disable the BIOS and HDD passwords. I even had to re-enter the password in order to disable it, and that worked!
However, the remaining problem is that I now have a perma-locked Samsung SSD (not cheap btw), and I need to know how to unlock that. If I put it back in the computer, I get prompted for the password again, which.... doesn't work. :(
My only guess is that the computer is somehow munching or crunching the data that it sends to the drive to set the password, since I WAS able to unlock the integrated iSSD but not the Samsung drive that I had installed. With the Samsung drive installed, I cannot even enter the BIOS in order to set or clear passwords - it just won't let me get that far.
PostPosted: September 25th, 2012, 9:15
At this point, I'd prefer to just get my drive back, no data. Will a secure erase work on an SSD while it is locked?
I had just finished customizing my new OS install :roll: and discovered that the ASUS BIOS must not send the password to the drive correctly. :shock:
I have an old T61 that lets me boot and send commands to the locked drive, if I insert the drive after the POST sequence. I just don't know what commands to send.... Can someone help me out here?
PostPosted: September 25th, 2012, 17:00
Well, I ended up sending my SSD in for RMA, so I guess this topic can be closed.
PostPosted: September 25th, 2012, 17:25
I can't see any other DIY option for you, given that you don't seem to know either password (user or master) that was actually set on the SSD, based on your comments. :( And regarding your earlier question, no, you can't do a Secure Erase on a locked drive without knowing at least one of those passwords. :(
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 62 guests
