 Post subject: Seagate ST1000DM003 Cannot ID
PostPosted: September 26th, 2012, 11:11
All,
I have a Seagate ST1000DM003, FW: CC4C, Site: SU. Drive spins up and sounds normal. In Deepspar and DC the drive goes ready but you cannot ID from it (gives errors that the drive is not responding). In HD Doctor, terminal output upon power up is below:
Boot 0x40M
Spin Up
RECOV Servo Op=0100 Resp=0005[0x00026F7C][0x000273E8][0x00027854]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
RECOV Servo Op=0900 Resp=0005
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MCMainPOR: EXCEPTION: MCMT PRI copy corrupt
MCMainPOR: EXCEPTION: MCMT SEC copy corrupt
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = 000000C1
MCMainPOR: MCTBufferPtr->Header.MCTStateFlags = 0000002E
MCMainPOR: MCStateFlags = 000000C1
MCMainPOR: EXCEPTION: POR Failed General
MCMainPOR: Feature Disabled...
PowerState = IDLE1
PowerState = IDLE2
Anyone have suggestions on this? Or if you need more information, please let me know. I've seen similar posts on here regarding the "MCMainPOR: EXCEPTION: MCMT PRI copy corrupt", but the Secondary copy was valid and there was additional output not present in my scenario.
Dizi
 Post subject: Re: Seagate ST1000DM003 Cannot ID
PostPosted: September 27th, 2012, 11:10
Nobody has any theories/thoughts? Even a response of "Heads", "SA damage", or "Firmware issues" would help.
Dizi
Users browsing this forum: ad1479 and 68 guests
