 Post subject: Need help for data recovery.
PostPosted: September 27th, 2012, 6:24
Seagate Barracuda 1TB 7200.12
S/N : 9VP7J8R1
ST31000528AS
P/N : 9SL154-302
FIRMWARE : CC38
DATE cODE : 10454
SITE CODE : SU
STX - 720012 (B)
100536501 REV A
Here's what happened,
1. The computer hang for several second, then back to normal, several hour later it hang again for several second, working again, then after several minutes,
hang and then a message appear, said something like I/O error, press Esc or restart.
2. Press Esc, the problem persist, continue with restart, it goes pass the BIOS screen then black, nothing happened, only a cursor at the top left corner of
the screen.
3. Try to boot the computer using another HDD, while the Problem HDD being set to secondary, still can access the data, and only manage to take 1/10 of the
data, because running out of empty storage.
4. The next day, after got more empty storage, continue trying to recover the rest of the data, after login, the Problem HDD still accessible, and the file
can still be seen, and the several minutes later, it say HDD not recognize. and the drives gone from the list.
5. Restart the computer, Bios still detected the drive, still, it write something like ST31000528AS CC38, SMART Capabilities AND Status BAD, and Drive
Error, and stop in there, won't go to OS.
6. Go to BIOS and disabled SMART at the Problem HDD port, this time manage to enter the OS.
7. Login and proceed trying to recover the rest of the data, computer still detected the HDD and the files, after several minutes it say device not detected,
and the whole drive gone from the list.
8. Restart, and it happened again, detected for several minutes, and gone...
Please help me, anybody knows where and/or what is the problem ? What should I do to recover my data ?
Thank you very much for the help.
 Post subject: Re: Need help for data recovery.
PostPosted: September 27th, 2012, 7:50
Looks like you have bad sectors and/or a weak head on that drive.
You should try to image the drive, or a better way is to contact your local DR company...should not be to high cost at this stage
http://www.rescue-it.se
PostPosted: September 27th, 2012, 11:06
Agree, this kind of behaviour is typical for weak head(s).
PostPosted: September 27th, 2012, 11:15
Its a .12 seagate. There are a lot of possible faults. SA , heads , bad sectors. Most of the time DIY wont work. A suggestion to image the drive given by Mr Spokk is valid. Try using HDDCLONE. If it wont work - DR service is the only option.
PostPosted: September 27th, 2012, 20:40
Thank you very much, really appreciate it :good:
Going to try Mr Spokk suggestion.
Users browsing this forum: Google [Bot], michael chiklis and 87 guests
