October 6th, 2012, 22:35
I have a broken hard drive, apparently the problem is with the firmware.
I would like to extract the information from it. I tried to use the HDD Raw Copy Tool and it worked, it began extracting and outputing the information of the disk. I didn't finished doing because I was unsure of which format to use, and didn't want to waste time and space.
What format should I use to later recover the information from it? img or imgc?
After that, what program do I use to open it?
I understand all of the risks in doing it by myself. There is no vital and money-worth data in the disk, just family and personal stuff that I would like to get back.
Thanks in advance.
October 7th, 2012, 5:58
Before starting cloning, make sure that you can read actual data from the hard drive. Use disk editors to examine first sectors of the drive. I can't help with Raw Copy Tool, but it seems you are copying to image file and "imgc" is a compressed file.
If you don't know what it is, I suggest copy it to a physical drive, the same or higher capacity. Use free floppy/CD/USB bootable tools like R-Studio emergency disk or DMDE.
